Question about Coffee Makers & Espresso Machines
Expresso won't pour - Coffee Makers & Espresso Machines
Please, check and clean all fitters. Also checks for clotted milk and coffee in the pipes. An added advise could be to flush well with air theentire passages which are supposed to be frreways for your espresso.
Posted on Oct 27, 2012
The steam wand on a DeLonghi 3400 expresso machine leaks what's the problem
You probably need to replace the valve. Have a look at the video.
Hope this helps.
Jul 23, 2015 | DeLonghi Coffee Makers & Espresso Machines
My Coffee machine Delonghi doing expresso without foam today. Before doing good expresso with foam. help please.
Espresso should have crema not foam, foam is air added to coffee, like Starbucks does. Issue lays in the grinder and coffee quality. Recommend using Italian espresso bean like Miscela d Oro
Apr 14, 2014 | DeLonghi Coffee Makers & Espresso Machines
My 1985 grand Marquis won't start I can pour gas
Take the gas filter off. Should be located near the front of the carbeurator, take off the air cleaner and look for it, it takes 2 wrenches to take it off, a little gas may spill out but not much and replace it, however there is a strong possibility that he gas pump is out if the filter is fine. Hope this helps
Jul 11, 2012 | Cars & Trucks
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
My machine is brand new. I am pressing the expresso button for an expresso and it is not extracting to the full extent. I have to press twice. Does it need to be reprogrammed or something?
RTFM: if you press the button for the espresso AND HOLD IT for the time it needs to fill your cup, it is programmed in for the next time. It will then pour the same amount when you press that button only once. Or to be exact: the pump will run for the same amount of time as the programmed time.
Sep 12, 2011 | Nespresso Citiz D110
The machine pours too much coffee for an expresso and even for a normal cup. We have been using it for 3 years and this just started a few weeks ago. I reset the machine to factory settings and it still...
You don't mention if you've programmed the quantity since it started behaving strangely, so....
instead of pressing the 'coffee cup ' icon button once, hold it down all the way through the brewing procedure (it will bip) until the correct amount of coffee has been pumped into your cup, then release the button. This quantity has now been programmed into the memory and should produce the same amount of coffee every time, on a sigle press.
Mar 04, 2011 | Saeco Incanto Sirius Fully Automatic...
How to pour water in the expresso machine?
The water resevoir cap can be quite tight.
Jul 05, 2010 | Mr. Coffee ECM20 Espresso Machine
The water pours out the sides when I make expresso. The frother doesn't seem to work, either. I got the machine at Williams Sonoma over five years ago but I live in Guatemala and can't find anyone to fix...
the gasket needs to be replaced. I just had to replace mine. http://www.krupsonlinestore.com/product_detail.asp?T1=KRW+MS-620342&MENU=&SELECT=&SKW=xp4030
Apr 07, 2010 | Krups XP4030 Espresso Machine
Russell Hobbs filter, cappuccino, expresso, steamer coffee maker
I HAD A GE CAPPUCCINO/EXPRESSO MAKER GIVEN TO ME WITH NO MAUAL OF ANY SORT THE MODEL NUMBER IS 169069. I REALLY WOULD APPRICIATE HELP WITH THIS THANK YOU...
Jul 14, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
47 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
