Question about InFocus IN116 WXGA DLP Projector
Can someone help me reset my factory PIN for the in 116?
I cant find the factory pin and am now locked out. Please help!
Forgot pin code
Angie, You can may have to do factory reset. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Forgot Lock Screen Password or PIN
http://forums.androidcentral.com/samsung-galaxy-note-2/250290-omg-forgot-pin-can-t-get-past-lock-screen.html
Tablets and eReaders Faq
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
Apr 07, 2016 | Tablets & eReaders
Forgot my screen lock pin
If you have forgotten the screen lock PIN, you will have to perform a factory reset on the device, which deletes all data including the PIN. This process differs between tablets and is not trivial. See their directions for your device at https://geminidevices.zendesk.com/entries/23857527-How-do-I-perform-a-factory-reset-on-my-tablet-
Mar 28, 2014 | Android Gemini Tab
Akura hdd recorder,lost pin number,cant delete recordings.
If you have changed the pin from factory settings, then you need to reset to factory settings. Usually if you can factory reset it, the pin will be 0000 or 1234.
Sep 30, 2013 | Televison & Video
How to reset the pin for Panasonic DMR-HW120EBK 500GB HDD Recorder with Twin Freeview +HD Tuners (2012)
This is the definitive answer from Panasonic Customer Services. It worked for me.
In response to your enquiry, I am writing to inform you that you can reset the PIN number to the default 0000 and then change it, based on your preference. In order to reset the PIN, please follow the next steps:
1. Switch ON the unit;
2. Press and hold the OK, YELLOW and BLUE buttons, at the same time, until you see 00 RET displayed on the unit;
3. Press, repeatedly, the RIGHT ARROW buton until you see 03 VL;
4. Press OK and you should see "INIT" displayed on the unit.
This will reset the PIN number to the 0000 factory preset.
Furthermore, you should also be able to remove the message that is asking you for the child lock PIN while attempting to play back a recording. In order to do this, please follow the next steps:
1. Press SETUP;
2. Choose HDD/USB HDD;
3. Select CHILD LOCK FOR PLAYBACK;
4. Input the default 0000 code;
5. Switch it to OFF.
After performing these steps, the recorder should no longer ask you for the PIN when trying to playback a recording.
I trust that the above information will be of assistance to you. However, of course, if you should have any further queries, please do not hesitate to contact us.
Kind Regards,
George
Customer Service Team
Panasonic UK
Feb 19, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but...
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
Sep 23, 2010 | Deadbolt Locks & Locksmithing
Pin unlocking code
you have to reset all codes on the phone back to factory setting go into security and restor factory setting it will explain in phone handbook how to get to this then for the password type in eight 0 the phone will then restart and say done
Apr 16, 2008 | Samsung SGH-D500 Cellular Phone
Pin unloock
how do i unlock my garmin i never put i pin number but is asking me the pin is a garmin street pilot c 550 thank you
Sep 23, 2007 | Garmin StreetPilot c550 GPS Receiver
InFocus IN116 WXGA DLP Projector Logo
60 people viewed this question
Top InFocus Computers & Internet Experts
Marko Kmeti?
Marko Kmeti?
Level 1 Expert
jasbo
jasbo
matt
matt
Are you an InFocus Computer and Internet Expert? Answer questions, earn points and help others
