Question about Jenn-Air JFC2070KRS Bottom Freezer French Door Refrigerator
Compressor is humming and not cooling
The compressor sounds like it is trying to start (making a humming noise) then it stops. The unit is not getting cold on top or in the freezer.
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
Replace the start relay on the compressor. Here is the part you need.
Posted on Oct 28, 2012
HVACRH20
  • 237 Answers
SOURCE: refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Posted on Jan 02, 2007
  • 1462 Answers
SOURCE: Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Posted on Jun 25, 2008
SOURCE: Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Posted on Oct 03, 2008
SOURCE: freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Posted on Jan 18, 2009
  • 366 Answers
SOURCE: fridge top section is warm, not as cold as bottom
heat rise to the top, so the top will always be hotter than the bottom, it is reccomended to store things that can handle slightly higher temperature at the top and more temperature sensitive food at the bottom, althou i do not know how hot it is, so if it is nearing room temperature something is definitely wrong, either a coolant leak, a worn out compressor or a defective temp sensor
Posted on Jan 16, 2010
My GDM-12 is not cooling. when I turn the temp up it make a loud humming sound.
If the humming last 3-5 seconds then makes a faint click sound and stops humming for a minute or two. Then resumes the hum again it may be your compressor locked down. Stuck. Most likely it is just a bad start capacitor not kick starting the compressor. A $6 part.
Mar 07, 2014 | True GDM-12 Refrigerator Commercial
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Sub zero. 650 reefer. Significant hum coming from top mounted compressor, but still marginal cooling. Now a louder hum and unit no longer cooling.
Hi roger,
I see you concern, and if the unit does not cool anymore and there is a humming noise then you will need to replace or have your compressor repaired no doubt.
Have a nice day,
mvincentc
Jul 03, 2011 | Kitchen Ranges
I have a danby premiere model DPAC10071 & the dehumifier now wont fill external tank. every 2-3 minutes it makes a noise kind of like a fog horn way off in the distance(as if its trying to run again,...
it sounds like your compressor is failing to start ... that usually means a bad starting capacitor ... if thats the case it will hum loudly for a few seconds periodically .. thats the compressor trying to start but it cant if the capacitor is bad .. it will stop humming when it gets too hot .. a thermal breaker will turn off the power until it cools back down .. dont let this continue since it will eventually damage the unit ... replace the capacitor .. the capacitor is usually mounted on or near the compressor .. it often has two sections .. one for the fan motor and one for the compressor ... since they are both in one case you have to change them both ,...
Aug 15, 2010 | Danby Heating & Cooling
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
The fan for my air conditioner will not turn. When we cut the system on it makes a humming sound and the light go dim for just a moment and this goes on repeatedly. No heat or air. We have a dual...
If the humming noise is coming from the attic it would indicate that the blower motor on the air handler is trying to start but the rotor is locked.
If the humming noise is coming from the outside unit and the fan runs but the compressor does not your compressor has a locked rotor.
If the blower motor is the problem the outside unit should still start as normal but you would have no cooling due to no air movement.
In ether case it sounds like you need to call a service tech to diagnose your system.
May 03, 2008 | Heating & Cooling
Fridgedaire glrs237zcb3
about the only thing you can do here is take the back cover off the unit see if the cooling fan for the compressor is running if it is and there is an Indian on the compressor then the compressor should be replaced if the fan isn't running then clear the fan once its running then turn the unit off for 30 Min's and try again
Feb 11, 2008 | Frigidaire GLRS237ZA Side by Side...
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
Jenn-Air JFC2070KRS Bottom Freezer French Door Refrigerator Logo
171 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
