Question about Cuisinart 6 qt. Pressure Cooker
Parts for cuisinart model C89-24N
Need the spring for the red pressure indicator for the Cuisinart Model C89-24N
  • 3 Answers
SOURCE: Lights blink, but Cuisinart Smartpower 7-speed wont turn.
The thermal fuse is blown. You can buy a replacement from RadioShack for $1.69 You have to remove the old one and solder in the new one. If youre "handy" its very easy. Take it to a repair shop, you pay about the same as a new one. Its too bad that most electronics made today are cheaper to throw away and buy a new one rather than fix them when they break.
Posted on Aug 20, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart CRC-800
Here's that manual:
http://www.cuisinart.com/share/man/394_man.pdf
-Tha Mp3 Doctor
Posted on Mar 27, 2009
SOURCE: parts for cuisinart blender trio model bc-56
GO TO:
http://www.smallappliance.com/department.asp?cur=USD&sid=18954&mid=8&shopBy=Brand&cam=cuisinart_parts&gclid=CJTy7Om5qZoCFRk_awod9Gjw1Q
FOR CREDITS MAIL BACK TO: NEFIUINC@MSN.COM
Posted on May 07, 2009
  • 13 Answers
SOURCE: Cuisinart coffee maker turns on but will not brew.
Well, you could try unplugging for an hour. Sometimes that helps, but these have been having a lot of problems (but don't ask their customer service that, they can't admit it but I'm pretty sure they all know it!). I would say call customer service anyway if it's under 3 years old (800-726-0190) after you've unplugged it and let them know what's going on (model and serial # are both located on the bottom of the unit, stamped in the black part). If it's under warranty they can offer you a replacement and from what I hear Cuisinart has been getting in new coffee on demand units (like the one you have) that have fixed the problems. They're on back order right now though, so there will be a wait. Other than that, I would say you don't have many options, unless the store is willing to take it back, because this one is pretty much a goner. Not the first time I've seen it. :(
Posted on Aug 28, 2009
CUISINART RECALL PART DFP 14
Cuisinart Food Processors Recalled by Conair Due to Laceration ...
https://www.cpsc.gov/Recalls/2017/Cuisinart-Food-Processors-Recalled-by-Conair
  1. Cached
13 hours ago - This recall involves the riveted blades in Cuisinart food processors with model numbers that begin with the following: CFP-9, CFP-11, DFP-7, ...
Cuisinart Recalls 8.3 Million Food Processor Blades Dating Back To ...
https://consumerist.com/.../cuisinart-recalls-8-3-million-food-processor-blades-dating-...
  1. Cached
7 hours ago - Yet Cuisinart has recalled 8.3 million food processors in the United States and Canada that pose a ... Affected models: CFP-9, CFP-11, DFP-7, DFP-11, DFP-14, DLC-5, DLC-7, DLC-8, DLC-10, ... Part of Consumer Reports.
DFP-14 - Food Processors - Parts & Accessories - Cuisinart.com
https://www.cuisinart.com/parts/food_processors/dfp-14/
  1. Cached
DFP-14. White And Stainless.Png Color Swatch Matte Black Metals.Png Color Swatch Brushed Stainless.Png Color Swatch White.Png Color Swatch Red.
Dec 14, 2016 | Cuisinart Blenders
Where do I register for replacement blades for recalled blender blades?
Dec 14, 2016 | Blenders
Need manual for Cuisinart
The manual for the Cuisinart CPC-600 6-Qt (5.7L) Electric Pressure Cooker can be downloaded from the following link:
http://www.cuisinart.com/share/pdf/manuals/cpc-600.pdf
This is the commonly available manual for the Cuisinart pressure cooker. Do you have a different model? Can you provide the model number to enable a more detailed search?
Jun 10, 2012 | Cuisinart 6 qt. Pressure Cooker
Need replacement lid for Cuisinart DBG300
I believe your model is actually the DGB300. Available replacement parts can be ordered online from Cuisinart at:
http://www.cuisinart.com/discontinued/coffee_bar/dgb-300.html
Unfortunately it may be necessary to order the complete carafe. You may wish to try contacting Cuisinart using their web inquiry form to see if they are able to provide the lid as a separate part:
https://www.cuisinart.com/support/international.html
Jan 20, 2012 | Cuisinart DGB-300 Coffee Maker
I don't have an instruction manual (wasn't in the box) and I don't know how to use the slicing/shredding blades or the additional smaller bowls.
A manual for the FP-14C series which the Cuisinart site indicates is applicable to your specific model is available online:
http://www.cuisinart.ca/pdf/ibs/en/FP-14DCC_en.pdf
See page 8 for assembly instructions. Beginning on page 20 is an included recipe section.
For future reference available Parts & Accessories are listed here:
http://www.cuisinart.ca/cuisinart_parts_accessories.php?product_id=328&item_id=281&cat_id=7
Aug 13, 2011 | Cuisinart FP14DC 14 Cups Food Processor
Need to locate instruction video and recipe guide for DLC-10
Good find! The instructions can be viewed online, and the video can also be ordered:
Go to this page for the manual - the model is not the same, but this model operates exactly the same as your food processor:
http://www.cuisinart.com/catalog/product.php?product_id=28&cat_id=7&item_id=57
Go to this page for parts:
http://www.cuisinart.com/catalog/product.php?product_id=31&cat_id=7&item_id=60
Click "Parts for this model" for the video
Apr 18, 2009 | Cuisinart DLC-10S Pro Classic Food...
Parts for Cuisinart CB-600 SA Blender
You have a Sam's Club variant of the model:
The blender parts are the same for that model as for the CBT-500 - food processor parts are the same as for the BFP-703
All available from www.cuisinart.com
-Tha Mp3 Doctor
Jan 26, 2009 | Cuisinart Blenders
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Jul 15, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart grinder wobbles
The model that you have is Costco's equivalent of the DBM-8 - the parts are exactly the same, so enter "DBM-8" as your model # on the Cuisinart website for parts.
Jun 22, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Cuisinart 6 qt. Pressure Cooker Logo
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
