When switching on my konica 600 it boots up then crashes going back to egg timer, followed by booting up again back to egg timer, follows this cycle but not booting up fully
Mite need to have its firmware reloaded. or the machines NVRAM may be gone>
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Hi,
pretty sure is to do with main paper bin lift up mechanism try opening paper bins and using manual feed thru the side the try each bin in turn. hope this helps
SOURCE: konica minolta Bizhub C350. Following message
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
