Question about Kenwood Audio Players & Recorders
Kenwood KC-993 volume not working properly. Cannot be adjusted.
Volume cannot be adjusted. It's too loud on only 78
SOURCE: Volume not working on remote
Just get a universal remote like i did but i also had another technics remote from another unit.
Posted on Oct 01, 2007
SOURCE: Multi Room / Multi zone problems
As you may see from my posted response to a posting that correctly ID'd the solution, the answer to your problem is found on p. 47 of the manual (regarding how to adjust the multi volume levels as stated on p. 26).
Posted on Jul 31, 2008
  • 336 Answers
SOURCE: Volume Knob does not adjust volume, but remote does.
Check your owners manual for "factory reset" this will reset the main micro-processor. Otherwise the encoder (volume pot) needs cleaning, soldering or replacement. It could also be a cracked circuit board (if it has recently been hit)
Posted on Jan 29, 2009
SOURCE: i have a kenwood kc-992
i was wondering id you would be willing to sell your control amplifier? if you are interested please contact me at marge227@hotmail.com thank you for your time!!!
dunnbiker
  • 8546 Answers
SOURCE: My problems concerns the remote for Onkyo receiver
Batteries in the remote dying?
Posted on Feb 14, 2010
I have a Kenwood KC 105 preamp and the volume is stuck on high. I turn the volume knob but it does nothing. Any suggestions?
Looks like you are going to have to replace the potentiometer, AKA volume control. It must be shorted out inside (probably) or knob came off the shaft. (doubtful)
Feb 02, 2015 | Kenwood Sc-75 Av Surround Processor...
How do I adjust ringer volume on wired ATT two Line phone model 993
VOLUME buttons;
During a call, press to adjust the listening volume.
While the telephone is not in use, press to adjust ringer volume.
Oct 30, 2014 | 3M 993 Two-Line Corded Speakerphone with...
Turned on loud feature need to turn it off
Press the source button, press the volume knob for at least second, then press the volume button again, and then turn the volume knob and it it will scoll through the adjustments, the last one should be loud and press the volume button again to select off, press and hold for at least one second until it returns to the main screen, then you should be set
May 12, 2009 | Kenwood DPX-301 CD Player
The volume control on my KENWOOD TH-78A no longer functions
first of all check the volume control see if a wire broke off. but i suspect a cold solder joint on that volume control switch. if not check the board for a small crack.
Apr 10, 2009 | Kenwood PB-18,...
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
I found this thread when I was having the same problem with mine. Turns out that it's sort of a problem, but not really. Looking at the manual (which I found in another google search) I believe a "4" on the volume level corresponds to a default remote control setting. The remote varies the level between 0 and 10, but the "10" corresponds to the maximum volume setting on the preamp. So it actually works, it's just that the "4" reading doesn't change. There's probably a pin you can short somewhere to make that default to "10" which would be ideal. But I'm not sure where that is. Now on to my other problem. This particular preamp has a subtle 120 Hz hum...
Nov 15, 2008 | JVC RX-E100 5-Channel Amplifier
Kenwood installation manual help?
Click HERE for Kenwood support and manuals.
May 15, 2008 | Kenwood Audio Players & Recorders
Volume display
u sure when u go to 0 is it loud ? unplug it then back in reset all in menu
Jan 27, 2008 | Kenwood VR615 Receiver
69 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
