Question about Kenmore 43042 Front Load Washer
Kenmore 417 Frontload Washer - Motor goes if I give it a push.
Now, just to be clear, I don't have a service manual, nor am I very handy; however, I can get around with a multi-meter, and I have located the control board.
Current state: When placed into the start of a FINAL SPIN cycle, pump drains fine. However, when it's time to spin, I can hear the motor giving it's little chirps (they're very faint.. I can only hear it when I put my ear next to it).. but the motor does not move at all. HOWEVER, if I give the tub a little shove or turn when that little noise is taking place, I can kind of "kick start it", and it starts to spin. It even goes into full RPM super speed in final spin mode.
Current state in wash mode: Standard agitating clockwise/counterclockwise does not work on its own. Same thing.. if I give the motor a little kick start with my hand, it will turn.
From what I've read so far.. it sounds like it might be the motor control board. How can I test the going to the motor to see if it's getting enough juice to get it started? Also, what IS the voltage/amperage that I should be looking for?
Kenmore (Frigidaire): 417-42052100
Motor: Sole (made in Hungary) Moel 205850 AC-EL CL F 110V 16K RPM 5.50V
Thanks,
Neil
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
    Problem Solver:
  • 6 Answers
This problem drove me crazy. I thought the motor was bad after about a year and a half. Because the problem was intermittent and I could "force" the machine to work, I pulled the panel and listened to the sounds each cycle made, making a chart of what each sound meant to the cycle. I jiggled the wires at the motor and then followed them up toward the switch housing behind the cycle knob. When I jiggled there, I could recreate my problems. I found that the plastic housing to the switch control behind and below the cycle knob was not fully snapped shut, as the washer would go through the cycles, the drum would bump against this housing and cause the wires (inside) connections to jiggle, thus sounding as if the motor was not working. I removed the bottom panel, reaching up to the area behind the cycle knob, tracing the wires from the motor. I pulled the casing out (I had to cut through the rubber liner) and wrapped it with strong tape, and replaced it. I have not had a problem since.
Posted on Jul 11, 2009
On a stacked 417 Kenmore,what is the best way to get to the seal-tub
Here is a service manual for the stacked set. The model may be a little different but the repairs will be the same.
Oct 22, 2012 | Kenmore 98702 Stacked Washer/Dryer
I have a model 417 Kenmore front load washer which stopped running and shows a E 20 error message in the window. What does that mean and how can I get it operating again?
Check to see if you have an obstruction inside the pump. If the hoses and the pump is clear, then it would be the motor control module, located in the back left hand corner of the washer.
First take the fat hose coming off the the bottom of the tub, that goes into the pump, you can access it by taking off the rear panel. Inside that hose is a filter, that normally gets clogged.
Hope helps.
Aug 16, 2011 | Kenmore Washing Machines
I just replaced one of the suspension springs in our Kenmore 417 frontload washer. When I turned the washer back on and tried to run a load, it will run for about 5 seconds then stop for about a minute...
can you give me some explanation on what you did to replace the spring?. did you have to take the washer apart?. check the wire. maybe you forgot or did not plug all the way a connector. or came apart. my impression is that something came loose and the computer is not detecting a connection.
Feb 09, 2011 | Kenmore 44042 Front Load Washer
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore frontload washer and the fabric softener will not release into the drum. I have removed and cleaned everything. Model #417 43142200
It appears your dispenser solenoid has failed in this instance.
Dec 10, 2009 | Kenmore Elite 45986 Front Load Washer
Same problem as before - Kenmore Model 417 44082400
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 06, 2009 | Kenmore Washing Machines
Door opens on the wrong side
Usually not. If you can you will need a door kit from sears. But in most cases the manufacture does not want to mess with the doors seal, so they dont offer a change.
Jan 24, 2009 | Kenmore 44072 Front Load Washer
commui=nication error between main and motor control board
Jul 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load tumble action washer
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. Catriver...post back.
Sep 23, 2006 | Kenmore 43142 Front Load Washer
Kenmore 43042 Front Load Washer Logo
1,078 people viewed this question
Sal De
fordexpert
Robert Rankin
