Question about Acer Aspire 3680 Laptop
Mouse is not working
I tried installing the drivers but yet its not working
  • neil700 May 11, 2010
    Mouse, as in a USB mouse, or the touch pad?
Mouse not working
If you referring to an external usb based mouse...you try to use and the computer does not see it ...In this case your mouse need a driver .. for it ..or ..usually all mouse are installed automatically by the system ..all you have to do is insert the mouse and restart the laptop ..and make it work ..Try it ..and if the laptop will not install the driver for the mouse automatically ..Look in the device manager and see which driver is missing and may cause it ..
another way to install the mouse is to run the add new hardware wizard from control panel ..select already added if it does not find the device right the way ..and guide it for the mouse you already add..
if it is a usb mouse..try to use another port in case in this one is not seen ..Also you may take a look on the driver download and see if you installed all drivers ...you may need a usb driver for it ..
here is the support site link ..
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3795238#N728
Oct 17, 2011 | Compaq Presario CQ50-215NR Notebook
My new mouse does not work with my hp computer
You may need to install device drivers for your mouse to work properly. If your mouse came with a cd, this cd should have the drivers. Insert the CD and install the drivers.
Alternatively, you can do a google search of the mouse model and find drivers directly from the manufacturer.
If drivers are installed, and the device still does not function properly, it may be malfunctioning. Try contacting the manufacturer for technical support.
Also, after you install a new mouse it is best to reboot the computer.
Regards,
G33k
May 05, 2011 | Computers & Internet
How do i get a mouse to work
For any peripheral accessory to work (keyboard, wireless mouse, printer, etc.) you need to have the drivers installed on the PC. You should try to Google the brand and model of the device and search for the drivers for your mouse. For example, If the mouse is a Microsoft Optic 4000, Google Microsoft Optic 4000 driver. One of the top 2-3 links should provide you with a way to install the driver. After install you may need to restart your PC but it should work then.
Mar 10, 2011 | Coby Kyros 716829701508 Tablet PC
Mouse not responding
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
May 18, 2010 | Logitech Webcam
Microsoft wireless notebook mouse 3000 won't work
Sounds like the driver isn't installed to your computer. Did the mouse come with a disc? Insert the disc into your pc and install the driver for the mouse. It should walk you through the installation process. Once the driver is installed your laptop should see the mouse and load the proper driver for it.
Cheers!! J the Guru
Jul 30, 2017 | Microsoft Wireless Notebook Optical Mouse...
Optical Mouse Model AM-3055U will not work on this computer
My same model Argos mouse was auto-detected as a "USB compliant mouse" and it failed to work. Went into device Manager and manually re-installed driver as a "HID compliant mouse" from local drivers and it works!!
Yrs, Mad-****.
Jun 27, 2009 | Toshiba LCD Display for Satellite Pro...
Unable to connect to the synaptics pointing device driver
Go to Start -> Control Panel -> System -> Hardware tab -> Click "Device Manager" -> Find the item called Mice and pointing devices and click the + sign.
If synaptics is listed right click and select Uninstall.
After that completes go to the top of the Device Manager and select Action -> Scan for hardware changes...it should find the device and attempt to reinstall it and the driver.
Thanks for using FixYa - If you
Apr 29, 2009 | Logitech Marble Mouse Trackball
Cursor not moving on screen
When you plug in the mouse you need windows to pop up and say found new hardware,and it will install a generic driver. I would shut down and restart and then plug it in again, if this does not work try installing the driver from disk that came with mouse, unplug mouse, install,plug it back in and try it.
Hope it works for you.
Mar 21, 2009 | Microsoft Wireless Optical Notebook Mouse...
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
My USB dell mouse (or any mouse) is not working.
Download updated mouse drivers from the Dell website
Nov 02, 2007 | Dell U0636 Mouse
Acer Aspire 3680 Laptop Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
