Question about Frigidaire GLER642A Electric Dryer
How do i test the sensor on the blower fan on my dryer
Makes a buzzing sound, but motor doesn't start. Will spin freely by hand.
2 Suggested Answers
mrfixit3667
  • 262 Answers
SOURCE: when i go to start my dryer model # aeq6700fso all
If the motor is hummming or buzzzing it most likly the motor or a bad wire conection to the motor.
you can try to turn the drum by hand and retry to start the machine.. if this does work, you have a bad spot on the motor and if it does not and you can verify the noise is coming from the motor then the motor is most likley bad.
Posted on Oct 06, 2010
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
How to get to dryer drum. GE mod#dbvh520ej2ww
Hello there and welcome to fixya
The most common problem with these are the motor or the motor bearings or rollers
and next is clothes getting caught between the drumb and the shell of the unit
Here is some troubleshooting help for you listed below
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor
Dec 15, 2011 | Whirlpool Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Heatman - you comments are always dead on. You've help me extend the life of my dry twice. My current problem is this: When starting the dryer, the drum will not rotate, and the motor makes an...
it could be the extra weight on the motor and the motor is bad,try this,open the door,push the door switch in with one hand and spin the drum with the other hand and have someone push the start button,if it runs and most of the time it does because you're helping it along you need a new motor.one more thing,if the filter is in front,remove the duct that the lint filter slides into and spin the drum,if the blower wheel moves with the drum you have a bad motor,if it doesn't you have something stuck in the blower wheel and it jams up the motor because it's attached to the motor shaft.
Jun 10, 2011 | Dryers
When i push the start button the dryer makes a buzzing sound and will not start up
you may have a shorted winding in the motor. check that no object is in the blower fan and that you can move the fan freely. if that is the case winding is bad. if fan moves hard the motor bearings bad, in ether case replace the motor.
good luck to you.
Feb 09, 2011 | Frigidaire FER311FS Electric Dryer
When pushing dryer start button, a slight buzz is
the noise is coming from the motor,if you can spin the drum by hand and it moves freely you have a bad motor and need to change it out,next time send model number and the brand name of dryer,if it doesn't spin,the belt could be jammed up or something stuck in the blower wheel,let me know how you make out
May 13, 2010 | Dryers
RUUD UBHA-14 J11SFJA air handler. The fan (blower) doesn?t runs
Absolutely, however, you want to properly diagnose the reason why the fan is not running. It could be a less expensive part than the fan motor itself.
First, check to see if you have the proper voltage going to the motor. I believe your motor requires 240volts ac. If you do not have 240 volts, you have a control problem.......either the thermostat is failing to close R & G or your blower relay may have failed to close the contacts necessary for your fan to operate.
If you have the voltage, then you want try spinning the blower wheel with your hand. Does it spin freely? Is the motor warm/hot? If so, turn everything off for an hour or so. As soon as your energize it, try spinning the motor with your hand again.....if it spins freely with no resistance and then starts running by itself, the problem is the run capacitor (approx $20.00 depending on where you purchase it from). If there is resistance when you try to spin it, the problem is most likely with the bearings and you will need to replace the motor.......if you have to replace the motor, go ahead and replace the capacitor also, making sure it is properly "matched" with your new motor.
I hope you find this to be very helpful to you, moving forward. :-)
Mar 28, 2010 | Ruud Handler Air Conditioner
Dryer won't start. Just makes a buzzing noise.
see if you can spin the drum by hand,if you can sounds like you have abad motor,or something could be stuck in the blower wheel jamming the motor and the belt broke but the sound is the motor,you need to get in there and look,let me know what you find and if i can help you with anything else
Mar 18, 2010 | Amana DLE330RAW Electric Dryer
When I press the start button on my LG front loader I get a buzzing sound & it won't start. No error message and lint is all clean??
If it makes a loud grrrrrrr sound then the motor is bad Or a sock or something may have got past the lint filter and is keeping the blower wheel from turning.
Spin the drum a few times both directions by hand and see if it turns freely.
Jan 15, 2010 | LG Dryers
Frigidaire GLER642A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
