Question about Sony Playstation 3 (PS3) Console
Ps3 solid red light
PS3 stuck in standby mode, solid red light. Cannot turn on machine by pressing power button or with controller plugged in usb. Disc drive can eject and will beep 3 times when no disc in.
bassplayer97
  • 154 Answers
SOURCE: ps3 wont turn on using controller and power button...
try cycling the power on the back of the console
are the lights blinking on your controller when you press them?
Posted on Jul 11, 2009
  • 60 Answers
SOURCE: When I turn on the PS3, the orange light shows,
sounds like a brick. Phone sony support.
Posted on Aug 12, 2009
Seth Wolf
  • 12 Answers
SOURCE: when i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Posted on Dec 06, 2009
gameaction
  • 89 Answers
SOURCE: disc will not eject
Disc stuck is not a big issue. Don't waste money to find someone to fix it yet! It may be a minor issue that you can be fixed by yourself.
Remember, you are not the only one to suffer this problem! Because I had help so many people to fix the same problem now. You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved the same problems after bought this guide. The author of the book is really kind and helpful to his customers. May be you can buy it and share what you have learned !
PS3 Repair Guide
Posted on Jul 11, 2010
  • 4102 Answers
SOURCE: I was busy playing a
Hi this is a very common problem and its to do with the ps3 over heating,
try the following.
leave it off and unplugged for an hour
check all air vents are free from fluff and dust and vac if needed.
make sure the ps3 is not being used whilst its on carpet
make sure the ps3 is not sitting on top of another electrical item such as dvd or sky box as this will cause it to over heat a lot quicker.
make sure its not wedged in a confined space it needs to have plenty of room around it to ensure cool air flow.
unplug all the leads from the back of the ps3 and the telly then plug them all back in, doing this removes any static that may have built up, then switch it on.
if after doing the above it still dont work then this indicates that either the gpu or cpu chip has over heated, if you have any warranty left take it back you need to check on the ps3 web site to see how old your ps3 is as this fault is covered by ps3 warranty for a couple of years but you need to check this.
now as for getting it repaired, well its a bit hit and miss i repair them myself and if it was an xbox 360 then i would say the chance of it working again is pretty high but as its a ps3 then these can be a bit hit and miss if the ps3 has over heated a lot and fried the cpu or gpu chip or both then the cost of repair would not be worth doing as it would be cheaper to buy a second hand ps3 or even a reconditioned one.
its not the kind of repair you can do yourself as you need to know how to test the circuit board to find out if the chips have been damaged.
the only other option you have is selling it for spares, i buy the damaged ones for spare parts but you wont get much for it as it is, i mean you could pay for the repair and you may get charged even though it cant be fixed,
i always say to my customers that if i cant repair it i will only charge for the parts i used which is nothing but if i do fix it then i charge them the cost of the repair, usually if its beyond repair they let me buy it off them as i pay more than they would get from ebay as they sell on their for about 30 quid with the problem you have got.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
use google and search for the following.
how to fix ylod on ps3
or
ylod repair guide for ps3
or
how to fix ylod on ps3 using heat gun
search for any of the above, never pay for any guides their all free and i can always talk you through the process of doing this repair
if you have any warranty take it back as you get at least 12 month warranty
never use the guides that tell you to either use hair dryer or to put the circuit board inside an oven both these methods dont work and the oven method will destroy your ps3,
if your doing this yourself you will need a heatgun with temp settings ie 1 and 2 high heat and low heat about 350f is what you need,
make sure you get a repair guide
i repair these for £40 so if your unsure what your doing or dont want to risk making it worse then shop around for repair service and they will sort it for you i always give 30 day warranty
if you are planning on doing this yourself let me know and ill send you some link for sites that have lots of guides you can follow ok
Posted on Dec 12, 2010
#97.46c19650.1326242769.12911d82
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed
Good luck
Jan 11, 2012 | Sony Playstation 3 (PS3) Console
Tip
Fix PS3 "Corrupt Hard Disk"
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
Connect controller to PS3 screen. You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen. You will then see this screen. Safe Mode options screen
You will then see this screen. "The hard disk's file system is corrupt and will be restored."
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
on Feb 20, 2010 | Video Game Consoles & Games
Tip
How to fix your PS3 when the hard drive disk is corrupt.
Connect controller to PS3 screen. You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. You will then see this screen.
You will then see a screen. "The hard disk's file system is corrupt and will be restored."
on Feb 14, 2010 | Video Game Consoles & Games
Hard disc drive is corrupt
Take care
Aug 11, 2010 | Sony Playstation 3 (PS3) Console
How to fix a corupted hard disk for a sony ps3 ?
  • Put your PS3 in Standby Mode.
  • For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
  • Time to enter Safe Mode.
  • Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
  • Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
  • REMINDER: - BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
  • You will then see this screen. "The hard disk's file system is corrupt and will be restored."
  • The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Good Luck and have a nice day.
Thanks for using Fixya
Jun 09, 2010 | Sony Playstation 3 (PS3) Console
Hard drive cannot format
I wish you good luck.
Comments:
Apr 17, 2010 | Sony Playstation 3 (PS3) Console
Ps3 on screen is saying hard disk is corrupted
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
Hi my hard disk's file system is corruped how can i fix it?
Connect controller to PS3 screen.You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen.You will then see this screen. Safe Mode options screen
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Corrupt hard disk
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
My PS3 hard drive is saying ''corrupt''. I have only use this system 15 or 20 times total. Is there something I can try before having to buy a new hard drive? When I turn it on, it goes to a screen that...
Feb 14, 2010 | Sony PS3 40GB Best Sellers Bundle Console
Sony Playstation 3 (PS3) Console Logo
181 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
