Question about Bosch Brute Breaker Hammer 11304
What causes the bosch 11304 to pass grease? - Bosch Brute Breaker Hammer 11304
3 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: bosch brute 11304 runs but does not hammer at bit
Sounds like you have a broken connecting rod. The easiest way to check for this is to remove the 4 cap head bolts holding the cylinder on and remove it. If the hammer piston comes off with the clinder you should be able to see the break. If that is ok you may have some stripped gears or a broken spindle somewhere. But I really think it is the connecting rod.
Posted on Sep 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: where do you locate the
you would have to look at the nameplate data for this information, there should be about a 9 or 10 digit number and this would tell you exactly. If you need more assistance let me know.
Posted on Aug 16, 2011
Do you have to grease or oil anything on the bosch jack hammer
Grease bosch order nr 1 615 430 001 225 ml for 1 service OR 1 615 430 007 1000 ml for bulk repair.
Mar 16, 2013 | Bosch Brute Breaker Hammer 11304
what caused grees to round down chissel from bottom of tool
Mar 26, 2012 | Bosch Brute Breaker Hammer 11304
How to fix jackhammer it doesnt hammer.
Bosch hammer drill 11304 uses sds bits and is generally a good hammer. Usually only needs yearly (depending on use) lube with Bosch grease to keep it working well. No hammering usually means lack of lubrication or broken connecting rod on the hammer piston. Not easy to repair. Tackle only if you have lots of experience with Bosch or other complicated hammers. Parts are easy to find. Good luck.
Mar 02, 2012 | Hammering
How much and what type of lube do i put in the area where the piston and crankshaft are located?
Best practice is to purchase service kit part # 1617000050 . It is available from several outlets including link below. The kit includes items that need to be replaced at time of lubrication.
If you do not want to purchase the kit then use Bosch 1615430015 Hammer Grease 15oz
Mar 08, 2011 | Bosch Brute Breaker Hammer 11304
How do I drain the gear oil from a Bosch Brute Jack Hammer
Brute hammer uses special grease sold as service kit. This kit contains enough grease to lube hammer and replacement bolts that hold springs along the bottom. Check www.toolpartsdirect.com for parts and kit. Remove the lower half (tube) of hammer, also remove three bolts that hold springs and remove assembly from tube. Wash out old grease. Grease will be oil-like only when hammer is very hot, otherwise grease is paste-like. Good luck.
Jun 22, 2010 | Bosch Brute Breaker Hammer 11304
Bosch Breaker Hammer Service Kit Install
The grease in the upper drive area used to be a purple looking grease and the grease in the barrel was a different color and weight. If you ordered the rebuild kit with the O rings and bolts I would use it in the barrel (light film coat on the parts )
May 10, 2009 | Bosch Brute Breaker Hammer 11304
Bosch Brute Breaker Hammer 11304 Logo
88 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
