Question about Unwired F0H-11099 Consumer Headphones
How to connect Unwired R1H-11099 headphones without packaging or manual
I just purchased 2 headphones from second hand store. How do I get them to work with my wireless laptop?
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
How do I connect my wireless headphones to my ipad
You go to your IPad Settings, make sure Bluetooth is on.
then turn on your headphones. You should see the headphones appear in Bluetooth list. ( see my example , I have a wireless keyboard that I have turned off but is paired).
Your headphones may have a button you need to push but not likely.
Oct 04, 2016 | Audio Players & Recorders
Can not connect to a laptop
Could be the laptop needs a driver installing for it to work.
Conventional bluetooth and wireless needs a 2-way signal so the item you want to connect will appear in the laptop wireless and bluetooth menus and you can click on it and enter a password or pin number.
If the headphones don't appear in the menus you won;t be able to connect them. In that case you should refer to the headphone instruction manual.
Apr 16, 2016 | Bluedio Model R - Wireless & Bluetooth...
Where do I attach audio output for headphones.
Excuse me brother, but if you have the owner's manual and the TV set in front of you, actually you are in a better position to find audio output. I don't have YOUR manual. Anyway, you can download one from the link I'll provide you, maybe it is more explicit then the one you have
Look at REAR panel and search for word "AUDIO OUT". If the plugs of your headphon won't fit AUDIO OUT connections take it a photo and go to a computer parts shop with your headphones ans purchase the appropiate converter
http://www.hitachiserviceusa.com:8080/55HDX99.pdf
Apr 20, 2015 | Hitachi 42HDT79 42 in. Plasma Television
Received headphones for tv the wireless ones
Contact the store that sold you the headphones and demand the charger. Of course unless the headphones runs on regular batteries and not rechargables.
Secondly, this is a thread for laptops, not headphones ;-)
Feb 21, 2015 | Computers & Internet
Can I use an UnWired R1H 21320 headset with a television
if the television has an audio output connector you can certainly use any headset.
Nov 24, 2011 | Radio Communications
I would like an operating manual for the UFR-308 2b way radio
There's little info available on these radios. The manufacturer has a specialty making wireless headphones and other automotive electronics. The company's logo however is identical to those displayed on the radio, so they should be able to get you what you need - or at least direct to where you can get it.
Contact UnWired Support by your choice of mail, email or telephone at this link.
I hope this helps - and good luck! Please rate my reply - thanks!
Jan 19, 2011 | Unwired UFR308 (14 Channels) 2-Way Radio
I have HDR65/RS65 Sennheiser wireless headphones. I disconnected them to move stuff around, then re-connected them. Now all I get is a 2 second cycle consisting of: 1 second of static that builds in...
Try connecting them to an MP3 player or connect wired headphones to the same source to make sure the sound source is working correctly. If that works, verify the voltage on the batteries is 2.4 volts after charging. Mine stopped charging fully and the headphones wouldn't work at all, but when I connected a couple of AAA batteries to it in series, it worked great.
Nov 15, 2010 | Sennheiser RS 65 Consumer Headphones
Microsoft office professional 2007 product key
The 25-character product-key is found either on the packaging, if you purchased the software at a retail store, or it is found in your E-mail, if you made an online purchase, or it is found on a credit-card-sized piece of plastic, if you just purchased a license-key (without the packaging and the CD-ROM) at a retail store.
Oct 19, 2010 | Microsoft Office Professional 2007 Full...
Unwired F0H-11099 Consumer Headphones Logo
160 people viewed this question
Top Unwired Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Unwired Audio Player and Recorder Expert? Answer questions, earn points and help others
