Question about Lexicon Mx200 Reverb Delay 1u Effects Processor
Lexicon mx 200 preset knob frozen
Preset knob numbers scramble and does not work
    Genius:
  • 1,212 Answers
If unt was dropped, look for broken PC board in the vicinity of the rotary encoder. Also look at solder connections to make sure they are sound. A little contact cleaner applied to encoder through an opening so the spray gets inside will help clean contacts. If the knob itself is hard to turn, the shaft is likely bent, and there may be damage to the encoder itself.
Posted on Oct 28, 2012
Lexicon alpha and gxl2200 microphone
Are you trying to use the mic input on the back or plugging it into the instrument input on the front? If you use a low impedance mic with a quarter inch instrument input cord, you would need a transformer adapter to make the mic work on high impedance. Even if you put it on line in, you would still have to convert it. Only the XLR socket on the back will work on a low impedance mic.
Mar 05, 2013 | Lexicon Alpha Personal Recording Studio
Alesis Quadraverb Q2. When I turn on Alesis Q2 the programs 1-100 preset are working but when I turn on programs 200-300 user It does not work. There is only "bad program" characters on display.
The Problem is a dead battery which is soldered to the circuit board inside the unit. It's a Panasonic BR-2325-1HC, but really you can replace it with any similar 3V battery.
Here's how I fixed mine.
http://andrewapeterson.com/2013/08/fix-alesis-q2-first-made-strange-sounds-then-bad-program-issue-quadraverb-2-battery/
Feb 07, 2013 | Music
Cannot format or reload factory presets after it stopped working
The card that you used to transfer the files HAS to be (1) FORMATTED by the ESX-1 unit FIRST, (2) then put the card into your computer's card reader and download the files. (3) Put the card BACK into the ESX-1 and try reloading the factory presets. Good luck!
Jan 11, 2013 | Korg ESX1 Electribe SX production station...
I have an I-Onix u42s which worked great up until today when I turned it on and it's not picking up any input sounds. I tried every input and no sound is coming through. I changed nothing on the...
Probably the sound and devices settings in Windows control panel have been clobbered back to the computer audio instead of the Lexicon. Check the device defaults in "Audio" and "voice" tabs in the "sound and devices" in the Windows control panel.
Jun 01, 2011 | Lexicon I ONIX U42S 4x2 USB 2.0 DESKTOP...
Hello i opened my lexicon omega and the cd wont download, i have tried a number of things but it keeps coming up with stienberg softwear, i have registered but the lexicon omega will still not load onto...
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
Apr 16, 2011 | Lexicon Omega Desktop Recording Studio
On powering up, the lexicons LCD display Audition light flashes for about 6-7 secs, then "21" appears then"UP". After this none of the buttons/Diald work-it just freezes. I have been...
hola tengo el mismo problema, me han dicho que actualizando el firmware de la lexicon mx200 se soluciona pero resulta que mi pc no reconoce el dispositivo via USB para actualizarlo, alguna solucion?? muchas gracias
Mar 18, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
I have Lexicon alpha, Condenser Mic, phantom power .If i record, the voice goes only to right speaker. I am using cubase le 4, stereo in/out are correctly.
Sorry, but the Lexicon Alpha does NOT have Phantom power and you can't use a condenser mic with it without a Phantom power injector or preamp.
If you mean you have a Phantom power injector then it should be working. Do you have seperate mics for the two channels of the stereo? If you have only one mic, then only one side will record unless you set for mono recording and then dump the recording into stereo voa Cubase. I would recommend you get a small mixer... even a 4 channel one to use ahead of the Lexicon so you can mix and PAN your mics the way you want them. The recording and trying to control the panning in Cubase can be frustrating... The Lexicon really doesn't have anything built in to PAN the mic to the center when stereo recording. Small mixers are inexpensive and often you can find them used or in pawn shops for cheap.
Feb 12, 2011 | Lexicon Alpha Personal Recording Studio
Whats the polarity of lexicon ionix u22 audio adaptor? should i set plus or minus polarity on the adcd transformer/adaptor? thankx
Easy answer: You DON'T set the polarity because this particular device takes a 9 VAC at 2.1 amp adapter. (Not a DC one like so called universal ones)
It sounds like you have one of those universal adapters which probably would not deliver the 2.1 amps required even if the lexicon took DC. Note that stuff might light up, but the unit will not work using a DC adapter..
You had better get an official power supply for this unit as what you have will NOT work, period!
I did a quick search to try and find a link to a supplier, but they are RARE !!! Every one I found would require you changing the plug to match the Lexicon.
You should just order the correct one from Lexicon.
Feb 04, 2011 | Lexicon U22 Ionix U-22
Cyber Twin selector knob.
The selector knob may be a potentiometer or a rotary impulse giver device. In any case, it looks like the internal contacts are either dirty or oxydized so the value is changing in an erratic way which causes the unit to skip several presets at a time.
It would require a skilled technician to disassemble and clean the controller (if it can be disassembled in the first place), otherwise you will probably need to replace the preset selector knob entirely.
Regards,
Triarcuate
Oct 07, 2009 | Music
Lexicon Mx200 Reverb Delay 1u Effects Processor Logo
201 people viewed this question
Top Lexicon Music Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Gil Shultz
Are you a Lexicon Music Expert? Answer questions, earn points and help others
