Question about Select Jazzy Used Electric Wheelchair
NEED NEW BATTERIES - Select Jazzy Used Electric Wheelchair
Satellit 800-batt blinks w/new Duracell alkaline batteries.
Have you checked the voltage on the new batteries.??? Some batteries, even if they are new... have a short shelf life, if they aren't used. You will need a volt meter or battery tester...if you dont have either, take the batteries to a Radio Shack or even a Auto store and ask them to check it for you.
Oct 20, 2014 | Cameras
I put in new batteries...the camera works fine for four or five pictures and then the battery message comes on that I need new batteries. Sometimes that message comes on before I even get to take a...
Same here, not the batteries
1.2v rechargeable Radioshack 1600mah & 1500mah did work though...
If you eventually get it to boot, go to menu and pick coolpix batteries.
Apr 07, 2011 | Nikon COOLPIX L20 Digital Camera
Camera saying batteries exhausted,when new batteries in
You must use good alkaline batteries or better, a set of high capacity NiMH recharegables. Zinc batteries just aren't up to the task.
New rechargeable batteries are supplied only partially charged. You need to charge them fully before use.
Oct 28, 2010 | Nikon COOLPIX L20 Digital Camera
Batteries don't last but 2 or 3 hours after taking 20 to 25 pictures on 2 gig card batteries are gone.
What kind of batteries are you using? what is the milliamp rating on the batteries? Are they still the stock sanyo batteries? If you are using flash and the screen it can wear out batteries pretty quick specially if they have been recharged alot of times. If they are not new then you probably need to invest in a new pair of rechargeable batteries. If they are new batteries check to see if the MAH rating on the bat tery is higher or lower then the old ones. If you want to buy new ones click here
Let me know from there and i can assist you further. Thanks, Midwest-tek
Aug 29, 2010 | Sanyo VPC-S670 Digital Camera
It won't charge. it lights up but does not turn on Remington Microflex R-845 shaver Does it need a new battery? if so, where do I get one?
It probably needs new batteries. You will find the batteries at shaveroutlet.com. See link below. You will need to order two batteries.
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Replacement instructions:
Remove the two screws on the back to remove the back cover. Unsolder the wires connected to the batteries and solder in the new batteries the same way you take out the old ones
Mar 26, 2010 | Remington Microflex R-845 Electric Shaver
I pulled the batteries out of the camera before it had completely shut down. now it doesn't work at all. What do I do
If you waited for a long time after removing the batteries then batteries may be complitely shut down. Waited batteries always do that. Use new ones. If the old batteries rechargable then you should charge them again.
Feb 24, 2010 | Kodak EasyShare Z740 Digital Camera
Batteries continually need to be replaced. New
You have a leaky capacitor abusing your batteries so it needs repairing
Jan 19, 2010 | Kodak EasyShare C340 Digital Camera
Camera shows "exhausted batteries" with new ones.
i have this camera and i had the same problem
everytime i put in new batteries like 5 seconds later the battery was exhusted i tried cheap and expensive batteries but nothing seemed to work
i would recomend rechargealbe batteries because they last longer but if you prefer one-time use batteries you should change they battery type in the menu/ setup
hope this helps!! good luck
Jun 03, 2009 | Nikon COOLPIX L18 Digital Camera
My Polaroid i836 won't do anything. I bought brand new batteries.
I bought one today , and I had the same problem. I tried four brand new pairs of batteries and when I pressed the power button it just wouldn't work. I was going to return it tomorrow, but decided to try it again. I inserted the batteries that it originally came with and it finally worked. I tried the other batteries and it worked also, but not on the first try, in the third or fourth try. Maybe on the first few tries the batteries need to warm up? Anyway, it's working now.
Jan 12, 2009 | Polaroid i830 Digital Camera
Select Jazzy Used Electric Wheelchair Logo
103 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Colin Taylor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
