Question about Champion 3500/4000 Watt Portable Generator
I bought a champion generator 2 yrs ago.It ran when I bought it. Have not occasion to use it until now. It will not fire. It had some rust on the flywheel. Removed the rust. I replaced the spark plug.
It is a champion 6000
  • 44 Answers
Probably only one of these issues to cause that. gas not turned on or flooded- ck spark plug to see if it is wet, check to see if the spark plug is getting power by taking it out leaving the wire on it and holding it about a 1/8 of a inch away from some exposed metal part of the frame and have someone try to start it. if you get a spark then ck your gap and put it back. Ck your choke too to see if it is on. also if it was flooded then leave the choke off and keep trying to start it. if it was stored outside, it may have water in the gas.
Posted on Oct 28, 2012
How do i change the plugs on my 2000 1400cc suzuki intruder vs
You said you have fuel but do you have fire? It doesn't matter how long it cranks, do you have fire at the spark plug or not? Gotta have both.
Aug 04, 2014 | Champion International Champion& Small...
1996 chevy 3500 7.4 vortec. the ecm fuse blows at the turn of a key
One of the power wire going from your ecm to a sensor or solenoid is shorting to ground. Get a wiring diagram and an ohm meter. disconnect the battery and start checking each wire measuring from the wire to ground. as you wiggle you will see the meter show 0 ohms when it is shorted. These are the hardest and most time consuming kind of electrical problems .good luck
Nov 21, 2011 | Cars & Trucks
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
Installed a generac 20kw about a year ago, ran fine untill 2 days ago. During a utility outage, generator ran for about 30 minutes and then stopped producing power while still running. All mains were still...
With the engine off, check the exciter brushes and slip rings which supply magnetic power for the alternator winding in the stator. Also, check the motor-to-alternator mechanical coupling. Check the breakers for tripping. To service beyond this point requires a schematic of the alternator, a voltmeter, plus knowledge of what the schematic is telling you. Good luck!
Jul 25, 2010 | Generac Power Systems Generac 5525 20 Kw...
1986 ford ranger 2.9 liter 2 wheel drive
youll have to see if your coil is firing
Feb 07, 2009 | 1986 Ford Ranger 2WD
Coleman powermate 5000 gen.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clen the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Sep 17, 2008 | Coleman Powermate Powermate 5000W...
The shaft
Use steel wool to clean it, then be very diligent about putting olive oil on.
Dec 17, 2007 | Champion G5NG853S Household Juice...
Champion 3500/4000 Watt Portable Generator Logo
514 people viewed this question
Top Champion Televison & Video Experts
bobalix
Joseph Hoffmann
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
