Question about Frigidaire FGGF3054KF Gallery Series Freestanding Gas Range with 5 Sealed Burners, 5.0 cu. ft,, 2, 3, 4 Hours Scroll thru Self-Clean, 6 hours Timed Shut-off, 17,000 BTU Front Right Burner, 9,500 BTU Front Left Burner, 5,000 BTU Rear Right Burner, 15,000 BTU Rea
I was told that if I use the self cleaning application on my oven at high altitude(over 10,000 ft) it will break the appliance. Is this true?
  • 14,406 Answers
No,it will not.
Posted on Oct 28, 2012
Home Touch clothes Steamer! Won't turn on..
Steam is a tried and true sanitize. And unlike some abrasive cleaners, steam is both penetrating and gentle at the same time. It effectively sanitizes because it can reach high temperatures (above the boiling point of water) in pressurized atmospheres. And, by effectively re hydrating and breaking the bonds of muck and dirt, it's highly effective at spot-cleaning and deodorizing without all that rough treatment. And irons, of course, use steam to work the wrinkles out of fabrics when dryers don't cut it.
Sep 16, 2017 | Irons
All 5 spark igniters not clicking
Could be range of problems including:
Power not connected/turned off
Ignitor ports clogged
Incorrect operation
Manual is available via Google
Aug 09, 2015 | Frigidaire Gallery FGGF3032MF 30"...
Prob light stays on, prob is not connected. Will not allow me to heat the oven to a proper temperature or to turn off. Tried unplugging. Frigidaire fggf3054
Press the probe button and hold for 6 seconds.
Press self clean and toggle until "continue" message appears.
Press start to accept.
good luck!
Nov 27, 2014 | Frigidaire Gallery FGGF3054M 30"...
Bosch gas range error code F11
Disconnect the ribbon from the control panel and clean it using pencil eraser. then carefully reconnect it.
If the F11 is still there most likely it's the control panel.
God bless you
Feb 01, 2013 | Bosch Evolution 500 HGS5053UC 30"...
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
Frigidaire Gas Self Cleaning Oven door open in lock position
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
I have a black & Decker digital advantage iron. it is about a year old and when I plug it in it beeps and comes up with err or. Can you tell me what is wrong or what i can do
Hi!
I really hope someone can come up with an answer to your problem.
Personally, I have an iron, and a toaster, and a toaster oven with the old-fashioned dial where the degrees of heat are approximately displayed.
I had them for decades it seems, and I've never had to suffer any fallout from either ironing my shirts at plus or minus 5 degrees from the digitally recommended temperatures, nor from toast that was slightly darker one day and lighter the next.
I'm not a caveman, just in case you wonder. I do have a microwave oven with a dial timer as the only variable, and I must say on its behalf that it has served me without a hiccup the dozen times I used it to either warm my tea, or help defrost the odd TV dinner, which ended being cooked in the toaster oven.
In all seriousness however, needlessly digitally controlled appliances just because it's cheaper to manufacture them, don't score highly with me.
Furthermore, these electronic circuits appear to have a predetermined and highly predictable life expectancy, and oftentimes the appliances they control are cheaper to replace than to repair.
Feb 14, 2011 | Black & Decker Irons
Frigidaire FGGF3054KF Gallery Series Freestanding Gas Range with 5 Sealed Burners, 5.0 cu. ft,, 2, 3, 4 Hours Scroll thru Self-Clean, 6 hours Timed Shut-off, 17,000 BTU Front Right Burner, 9,500 BTU Front Left Burner, 5,000 BTU Rear Right Burner, 15,000 BTU Rea Logo
96 people viewed this question
Top Frigidaire Irons Experts
Thomas Perkins
Thomas Perkins
Ken Wieczorek
Ken Wieczorek
Are you a Frigidaire Iron Expert? Answer questions, earn points and help others
