Question about Maytag Dryers
Drying turning but not heating up - Maytag Dryers
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Oct 28, 2012
How do you turn up the heat on the dish washer drying cycle?
There is no way to turn up the heat of the dishwasher during the drying cycle. As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. But you can do these things to help with drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation during the dry cycle.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. That problem can be caused by a bad heating element, or by a bad controller.
Sep 21, 2014 | Whirlpool Dishwashers
How do I turn off the heated drying?
There should be a heated dry button under options.
Hope this helps.
https://www.maytag.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%206-917071.pdf
Oct 18, 2012 | Maytag MDB7100AWB Dishwasher
How do I turn off the heated drying cycle
Some dishwahers allow you the option of drying with or without heat. You should be able to select no heat
What is the heat selector knob?
This allows you to adjust the temperature to match what you are drying. Some fabrics and clothes require low heat or you may only be drying a small amount of clothes and don't need much heat. You also may not want high heat to avoid shrinkage of some clothes.
Jul 16, 2012 | Avanti D110 Electric Portable Dryer
Not drying. is there a safe way to test the heating element?
Hello there
Here is a detailed list of things to check to ensure that the element is your problem cause there could be a couple of different things also click on the blue items
If the dry cycle has a problem, check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Best regards mike
Apr 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dryer will not heat-up, clothes stay wet even after hours of drying! gas is on, gas bill payed,turning needlessly, no drying.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Nov 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dishes with a lot of water left on them.What's the problem? Heating element?
Yes. if this unit is not drying properly, it will be the result of a failed heating element. make sure you are selecting the correct drying method as well. if its on air, it will have a completely different drying time and attribute. if you are selecting the correct assisted heated drying method and, the dishes are not drying, replace the heating element.
***Using the proper rinse agent will increasing the drying performance as well.
Jul 17, 2009 | Frigidaire GLD2445RF Built-in Dishwasher
Not drying dishes
Without knowing the make and model of your dishwasher, the most probable causes of no drying is:
1.) RinseAid being empty or not dispensing (as in you never seem to have to refill the dispenser.)
2.) The Heating element has failed. But if it has failed, you would also have foggy, film on your glassware.
3.) The timer is failing to turn on the heating element during the (at least) the heating element during drying cycle.
Good Luck!
Apr 06, 2009 | Dishwashers
Not drying
is it electric?is the drum turning/are both your vent holes(wall&dryer)clear?mike
Mar 21, 2009 | Kenmore Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
