Question about Onkyo SKW-204 Powered Subwoofer
Does the onkyo skw 204 and skw 540 have the same connection in the back of the speaker. example line input and power cord
2 Suggested Answers
SOURCE: Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Posted on Nov 19, 2007
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Onkyo sub will not power up?
does the green light power up on the back? If not the power supply is bad
Aug 25, 2011 | Onkyo SKW-200 Subwoofer
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
I have an Onkyo Tsxr 577 amp. The wires on the speakers crossed and the amp stopped working. It might be in autoprotect mode and I don't know how to reset it.
To obtain service, take or ship your Onkyo product to an Onkyo Authorized Service Center. Please also include in any mailing a contact name, address and telephone number. Please include a copy of the original sales receipt/invoice as well as a letter stating what the problem is, with your name address and phone number so the service center knows who to return the unit to. Please note, before shipping, you must contact the authorized service center to inform them that you will be sending your unit in for repair.
Feb 22, 2011 | Onkyo TXSR577 71 Channels
I do not see any inputs to connect a subwoofer to my Onkyo A-9555 integrated amp. I would like to know if it is possible to connect it and what kind of subwoofer should I buy for that wit the best...
You amp has no OUTputs for a sub, but if you really want to attach a sub you'll need to get one that is self-amplified and accepts >>>stereo<<< High Level or Speaker Level inputs.
Otherwise your amp's volume control won't also control the sub's volume.
You would feed it full-range audio from the speaker terminals on your amp and its internal amp would use that to develop its own power output for the sub.
Here's one example.
http://www.ch.onkyo.com/files.download/skw-205_manual_e.pdf
Jan 29, 2011 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
My onkyo skw 200 sub woofer is blowing fuses as soon as i plug it in
The amp output stage or the power supply is shorted. Service shop type repair.
Mar 03, 2010 | Onkyo Audio Players & Recorders
Onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
No sound coming out of my Onkyo SKW-200 subwoofer
A subwoofer is just really a mono amp for the signal. As with all amps if you touch the audio section/parts with a small screwdriver, you should hear a buzz from the speaker. (Follow the audio wires to be certain you are on the audio section). This can be used for testing the amp section. If you get no buzz or noise (anywhere) at all then it's power supply could be playing up. If you have a multimeter you can test it looking to see if it is getting power. Allways suspect any part that is on a heatsink. Before removing any suspect you can put the part numbers into Google to see if you can get them and it will give you a clue to cost.
PS don't short any parts when you touch with a screwdriver, and don't put it on the power parts.
Feb 02, 2010 | Onkyo SKW-200 Subwoofer
I have an Onkyo SKW-50 subwoofer and when I turn on the power to the subwoofer, it is making a low-level humming sound. When I turn the frequency dial up or down, the sound of the hum gets louder or softer...
may be u have a power problem check if ur ground is well connected to ur amplifer and also check the input cables if there ground wires r intact and make good contact
Dec 20, 2009 | Audio Players & Recorders
Onkyo SKW-204 Powered Subwoofer Logo
83 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
