Question about Fuji FinePix S1 Pro Digital Camera
My S1Pro has stopped working altogether. It will not turn on. I have replaced the batteries and done everything that I can think of to try to get it going but to no avail. Any suggestions?
A ford territory 2006 that won't start, even after replacing battery?
check for battery voltage at the large terminal on the starter. THere should be power at all times.
Have a helper turn the key to the crank position while you check for power on the smaller wire at the starter. There should be power anytime the key is in the crank position.
If there is power at both terminals than the starter is bad. If there is no power at the large wire check your battery connection. If there is no power at the the small wire you will need to trace it back to its origin.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 08, 2016 | 2006 Ford Territory 4.0
How to fix 98 dodge caravan electrical / battery problems
Alternator voltage may be to hight that make the battery to dry out,or maximum output amp not ok and battery cant be fully charge
May 04, 2014 | 1998 Dodge Caravan
Garage door opener keypad stopped working. cannot reprogram it.
It could just be you need to replace the battery.
The warning light might be a "battery low" warning - advising you to replace it!
If it stops flashing, the battery has died altogether.
Nov 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back...
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Jan 02, 2009 | Kenwood KDC-128 CD Player
Remote control for JVC TV stopped working
1 if this new ordere it is exacly the same that should work when i say exacly that must have only the same button on it
2 you should try to take off the cover to that old remonte and try to clean the taste and then the change battery clean suport to battery wash your rubber taste and put all togheder and should work if that not hapened the problem it is from inside tv
and to that new one see if you have a shift buttun on it and push that or push tv button and try again should work
Dec 10, 2008 | JVC LT-26X575 26 in. LCD HDTV
Keyboard not working...
Have you pressed the connect button on the bottom (or side) of the keyboard. Having the mouse working means that all the rest of the kit is working, (as the reciever can connect to the mouse) if the keyboard will not connect (after pressing connect a few times)it seems that you have a dud transmitter in the keyboard, This does happen unfortunately (the oscilator crystal fails) if within warrantee try to get it replaced. Hope this helps
Aug 09, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Fuji FinePix S1 Pro Digital Camera Logo
47 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
