Question about Garden
Valve settings 21hp model 385777 type 0115-e-1 code 05012111
Back fire
3 Suggested Answers
mickey813
  • 472 Answers
SOURCE: Proper procedure to adjust valves on Briggs and
YOU HAVE TO REMOVE THE PLUG AND ROTATE THE MOTER TO T D C THEN TUR IT HALF PAST THEN CK THE VAVEL CLARENC ARE YOU SURE THIS IS THE PROBLEM TELL ME WHAT ITS DO ING SO I CAN MAKE SURE THATS THE PROBLEM LET ME KNOW
Posted on Oct 07, 2009
  • 252 Answers
SOURCE: need to adjust valves
hi edmeyers70
run engine to tdc compression stroke with plug out, and then set the piston 1/4 " past tdc on power stroke , then set the valve clearance at this piston position to ( off the top of my head about 0.003" inlet and 0.005" ex )
think these engines are briggs ohv single vertical
if you get model and type codes from your engine plate eg 351777-0112-e1
write yours down
here is web site
www.briggsandstratton.com
also www.partstree,com
go to briggs engine brand , select your engine series and then type code
parts diagrams will open up
cheers pauly46
Posted on May 21, 2011
Valve clearance Briggs model# 331877 1371b1
Danny, I set lash at .004" / intake and exhaust clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
briggs and stratton 21HP backfires like cannon
YTS3000 Craftsman model 917 289213 valve gap setting 331877 1371 B1 Briggs...
Lawn Mower Repair Valve Adjustment
Jul 08, 2016 | Garden
Tip
Need code for Emerson ET1932C tv set up my new
<span>Try these codes<br />0911 0520 0323 0115 0914 0213 0318 0247 0504<br />1 2 3 4 5 6 7 8 9 codes to try good luck</span>
on May 07, 2011 | Televison & Video
I need to program a Philips cl032 to my older model Emerson tv
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.
Mar 29, 2015 | Philips Televison & Video
Set valve clearance on 21hp briggs and statton
Valve clearances are set by either tappet screws in the lifters or on a lot of small engines, clearances must be set by either cutting out valve seats with a special cutter tool (to DECREASE clearances) or grinding the end of the valve (to INCREASE clearances) and generally are from .008-.010 on intake valves and .010-.012 on exhaust valves. Check engine specs to insure proper clearances.
Sep 24, 2014 | Garden
Owners manual for 008-09-0115
Kindly type your model number followed by 'operation manual' in google search engine. You will find a number of websites providing free manual. Just download it and follow the instructions there.
Jul 10, 2012 | TruTech PVS2119 19 in. LCD Television
I need the 4 digit code for my memorex TV
memorex TV 0002, 0502, 0506, 0706, 0115, 0704, 0601, 1302, 0428, 0632, 0701 OR 0002, 0502, 0506, 0706, 0115, 0704, 0601, 1302, 0428, 0632, 0701
Aug 16, 2011 | Philips PM3S Remote Control
Need to adjust valves on 21hp briggs&stratton,set at tdc or?
hi edmeyers70
write yours down
here is web site
cheers pauly46
May 20, 2011 | Garden
Engine starts and runs okay until I engage blade
I had the same problem on a 21HP, you are running on one cylinder. Take off the valve cover and most likely you will have a/some bent valve push rod(s) which is common on B&S V2 engines. They are cheap to buy but kind of tricky to install and properly adjust.
Jul 06, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Proper procedure to adjust valves on Briggs and Stratton, Vanguard Model 385777, type 0349-E1 engine
Oct 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
