Daewoo dvn14f6n i hvae a deawoo dvn 14f6n tv/vcr combo. the standby light flashes when off as opposed to being steady, and when i turn the tv on it says emergency in red letters, and when i try to eject the tape the indicator lights all flash once go out and then the tv shuts itself off? any suggestions?
    Top Expert:
  • Televison & ... Master
  • 76,016 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
Posted on Feb 15, 2018
5 Suggested Answers
SOURCE: DAEWOO TV/VCR COMBO DVQ 14H1FC LOST REMOTE
Hi, Sometimes the universal remotes are tricky.  If you don't purchase one that is specifically recommended by the manufacturer, you won't get full functionality.  Here is a generic that is "replacement" for that remote: http://www.daewoo.newremotecontrol.com/catalog_item.php?catnum=48B4139A02
Here is another place that has the replacement and an alternative: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12257602513440&smodel=48B4139A02&brand_pn=DAEWOO_48B4139A02
Hope this was helpful, have a great day!
Posted on Nov 04, 2008
premtech
  • 934 Answers
SOURCE: aewoo tv/vcr combo
Go here, http://www.remotecodelist.com/remotes/ look-up your brand remote scrolling down through all the differetn manufacturers - then click on link for what component it is you're looking up a code for and it should open a new page. Then look up the model and several codes should be listed...
Good Luck!
Bill
Posted on Nov 24, 2008
SOURCE: daewoo tv/vcr combo ccodes
Hi here are some codes I have 0278 0624 If they dont work try programing the VCR
first then the TV. To program the VCR put a tape in and put it on play after you put
the code in hit the power button the vcr should stop playing. If that works then program the TV.
Some TV/VCR combo's require two codes. Good Luck
Posted on Feb 19, 2009
SOURCE: TV Stuck in VCR mode
I used code 191 for my combo unit
Posted on Apr 03, 2010
How do I change from anntena to cable the menu dose not have a choice to do that
Hello, the original remote has a "tv/catv" button on it and that's how you select whether your on cable or antenna. tks
Nov 08, 2013 | Daewoo DVN-14F6N 13" TV
The menu does not have a choice to change from antena to cable how do I get it on cable
Typically, your cable box will have two inputs & one output that goes either thru your VCR for recording puposes or just direct to the TV. Your switching will happen thru your cable box, like an A/B switch, designed so that when cable is down, you can switch over to locally broadcasted TV stations. With DTV now in play in most areas, you will want to connect the antenna's connector to your DTV box, then connect it to your cable box for switching back and forth. The new flat panel TVs already have a digital receiver built-in, so in that case you would eliminate the DTV box.
I connected audio and video wires in front and I would like to swith to external input but there is no switch. I tried all different channels but does not work. How do I watch external device?
You must select "AV in" mode on the Remote to get the signals on this connection.. If your TV has more than one input (one at the back too) than you have a selection of "AV1" and" AV2 " to switch on these two..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Daewoo DVN-14F6N 13" TV
DEAWOO CTV MODEL NO.DTC2975 I wan to number of Vertical ic.
Hello
It may be either TDA8357J OR TDA8358J. Both are equivalents. OK.
Jan 04, 2011 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
My son's Daewoo#DVN-14F6N has Audio/Video, but are these Output, or Input...as I wish to connect a DVD player. Thx
that are input only. yes you can connect your dvd player, use a AV cable ( Yellow and White)
Sep 13, 2009 | Daewoo DVN-14F6N 13" TV
My tv is stuck in teh stand by mode...how can i fix this
Have you tried unpluging it for a few minutes, then plugging it backin?
Sep 08, 2009 | Daewoo DVN-14F6N 13" TV
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Need help changing from antenna to cable without a remote
have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
Feb 17, 2008 | Daewoo DVN-14F6N 13" TV
No Power... Main Fuse Blows right away. Resistor R809 has its outer layer burned off so I cant tell what value it is.
I would check the rectifiers (diodes) all 4; one or two may be shorted. Check color code for R809 or may have number on it if it is white square resistor
Dec 29, 2007 | Daewoo DVN-14F6N 13" TV
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
