Question about Kenmore Washing Machines
Washimg machine agitates and drains but does not spin
Motor coupler is ok and rotates
    Problem Solver:
  • 10 Answers
Mine had same issue. My problem was with the switch. Try gently wiggling the knob, then move it to the end of a rinse cycle, just before the spin cycle. Pull the knob out, and the timer should start clicking, after a few seconds you will hear a clunk sound as the transmission engages then starts spinning. I disassembled the unit and removed the motor, only to discover the coupler was not damaged.
Posted on Oct 27, 2012
SOURCE: Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Posted on Feb 14, 2009
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
  • 10865 Answers
SOURCE: Agitates and Drains, but no SPIN?
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jul 06, 2009
aasc
  • 1606 Answers
SOURCE: Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Posted on Aug 02, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Posted on Aug 27, 2009
Washer won't spin
Hello,this is usually a very common problem I have listed all of the possiable reasons and the troubleshooting solutions for you to check ok so just follow the soluition and click on the item mentioned : Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley. The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Thanks
May 22, 2010 | GE Profile WPRE6100G Top Load Washer
Tip
The washing machine wont agitate?
There are many possibilities for this problem. you will have to check all of them one by one mentioned as follows :--- There is a lid switch in the washer. The washing machine will not start spinning till the lid is closed. In some cases it has been seen that lid is closed still the washer does not agitating. in this cases the lid switch has to be checked. if the lid switch is faulty then the closed lid will not be detected by the washing machine, and it will not start agitate cycle.
But if the lid switch is ok checked, then other possibility can be fault in the motor coupler. Many a times the motor coupler is broken .The motor coupler is plastic/rubber kind of material fitted on the shaft of the motor .Check properly if the motor coupler seems cracked, worn out loose or broken then it needs to be replaced to solve the issue. But if motor coupler is checked ok then other possibility for this problem is the spinning belt. If the belt is worn out or loose or cracked/broken then it needs to replace.
Only for GE washers. In GE model washers, there is a clutch used for proper spin speed. If the clutch wears out, it has to be replaced.But if clutch/belt seems ok. then other possibility is driver motor itself .check if the motor has power if not then the motor is got internally burnt .in this case the drive motor needs to be replaced. but if drive motor is functioning properly then other possibility to be checked for this fault is the transmission shifter and pulley. If the transmission shifter becomes defective, the unit may drain the water but not spin. Replacing the shifter is bit time consuming and tough job. you will require proper tools to deal with this problem.. But if the transmission shifter is properly working then other possibility to check is the Agitator itself.If the transmission is moving properly but the Agitator is getting stuck and not moving properly then its the fault in the agitator assembly that has to be replaced to solve the problem. This will help.Thanks.
on Mar 18, 2010 | Washing Machines
Kenmore warsher, Model num 110.14202300, not drain or spin
The clothes too wet after spin cycle tells me that the water ump is functioning. If it wasn't, there would still be lots of water in the machine when the cycle ended. These Kenmores have the water pump mounted on one side of the electric drive motor and the transmission, drive shaft, and agitator on the other side. The transmission is fastened to the motor by a "coupler", a three piece assy that often breaks. This common failure allows the machine to complete a cycle, however, because of the broken coupler, there is no drive to the tub and no spin or agitate. The clothes seem wet because the spin motion is supposed to provide the force to extract the excess moisture. Leave the lid open and verify that there is no agitate or spin.(During spin cycle use a pen to press down on the safety interlock, a small opening on the the of the machine, toollow the unit to spin with the lid open). If you verify this, flip the machine over and locate the coulper on one side of the motor. One side will be cracked along the shaft. Sears parts stores carry the coupler in stock. ($18.50) Hope this helps.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Motor just humm's when put on spin. Doen's seen to
Assuming that this is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
There is a Sears repair parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of major sub-components will come up.
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) or spinning the solution points to a couple of places.
1. The motor coupler may be broken. This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
Remove the cabinet and inspect the coupler. Following is a good description of how to replace it if necessary.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The coupler consists of three pieces. Two plastic pieces with three prongs each that fit on the shafts of the motor and transmission and a rubber piece with six holes that the plastic prongs fit into.
If the prongs are broken off, or the rubber piece is broken, the motor cannot apply power to the transmission for agitating or spinning.
If the coupler is OK, the problem points to the motor or transmission.
If you move the timer to the spin cycle, and the machine drains the water , the motor is probably OK.
I'd also check the Lid Switch that prevents the motor from turning in the spin cycle.
Following is a Whirlpool PDf on how top load, direct drive washers work with a troubleshooting guide and description of how to bypass the LID Switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 02, 2009 | Kenmore Washing Machines
Kenmore 80 series, model 110-2781690, won't spin or agitate. loud clicking from lower portion of machine. fills & drains ok. transmission failure?
hi,
Unfortunately, it sounds like a transmission/gearcase problem, mainly because you stated the motor would run, but would not agitate or spin.
With the motor removed from the gearcase, try to turn the coupler on the gearcase side one way for many turns, and see if your agitator moves back and forth, then turn the coupler on the gearcase the other way many turns to see if the tub starts to move
thank you,
vijay
Sep 29, 2009 | Kenmore Washing Machines
Kenmore 24732 will fill and drain but will not agitate or spin
HI, Even tho it drains ok, does it spin? If it doesn't spin or agitate, it could be the coupler that attachec the transmission to the motor.The agitator is ok, it is designed to work that way. Please let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Kenmore 24732 Top Load Washer
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Wdsr2080
Need more specific information. Here's a list of possibilities, but you need to provide more info, such as: fills up OK, drains OK,
spins OK, etc.
Lid switch, motor coupler, belt(s), clutch, transmission,
worn agitator.
Dec 23, 2007 | GE WDSR2080D Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Will not agitate,spin or drain
There's a coupler that normaly goes.just tip the machine over and loosen the motor.the coupler will be 3 legged and plastic.just replace and it should be ok.
Feb 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
