Question about Whirlpool 6th Sense 40-Gallon 6-Year Tall Gas Water Heater Natural Ga
Register water heater - Whirlpool 6th Sense 40-Gallon 6-Year Tall Gas Water Heater Natural Ga
  • Whirlpool Master
  • 5,245 Answers
Whirlpool water heaters are made by AOSmith company, which owns American, Reliance, State, Craftmaster and makes water heaters for Kenmore and Whirlpool.
These are good heaters.
Register Whirlpool product at following link:
http://www.whirlpoolwaterheaters.com/support/warrantyreg.aspx
It is not necessary to register product for warranty to be valid.
And if you move to new home and take water heater, then warranty does not follow. So it might be disadvantageous to register product in that circumstance.
You can see brand, model number, and serial number located on label on side of tank.
The serial number is unique and is key for warranty coverage, even if you lost receipt. Serial number shows year of manufacture in first two digits.
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
It is not necessary to register water heater for warranty to be valid, as long as following applies: Original owner, single-family non-commercial residential installation, and installation that conforms to instructions shown in product manual, and water heater is maintained as shown in product manual.
If you purchased extended warranty, then remember the warranty is carried by a third party that also requires same as above.
And the warranty may be pro-rated, rendering it nearly valueless in later years.
Typical water heater warranty:
First year of warranty covers tank-parts-labor.
After first year, the warranty shrinks to tank-parts.
The math shows that shorter warranty tank has greater percentage of full coverage.
Convert ordinary 6 year tank into 9-12-15 year tank by maintaining water heater. Especially cleaning air intake located on bottom of tank, inspecting anode rod to prevent rusting, and following maintenance schedule shown in product manual.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Posted on Oct 28, 2012
Symptom: water gets too hot, before and after thermostats are replaced, burn mark and insulation swelling/melting on non-common wire from upper element to upper thermostat, and the breaker trips.
Double check the thermostat connection and setting; if it persists, I would add a pipe hugging thermostat connected to a shunt trip for the heater elements.
Jul 26, 2015 | Water Heaters
Can you wire up the heating element in a hot water heater wrong
you can indeed here are the steps to check you eliment
Turn off the breaker inside your main electric panel providing power to the water heater. Most electric water heaters use a 30-amp double-pole circuit breaker.
2 Look for the panels attached with screws to the side of the water heater. Depending on the size of the water heater, you will have one or two panels. Remove the screws from the panels to release them.
3 Remove the insulation you exposed when removing the side panels. Depending on the age of the water heater, the insulation is fiberglass or closed-cell extruded polystyrene foam. Wear safety goggles and gloves when removing fiberglass insulation.
4 Pull the plastic safety cover from the element face. This cover snaps on and off the element and thermostat.
5 Hold a noncontact voltage detector next to the wires connected to the element face, and next to each wire connected to the thermostat. If electricity still is present in the water heater, the voltage detector emits an audible alarm and its light flashes.
6 Loosen the two element screws. Remove the wires from beneath the screws. Make a note of the element wattage printed on the side of the element face.
7 Turn the dial on a multimeter to Rx1k (resistance times 1,000 ohms). Touch one of the screws on the face of the element with one of the multimeter probes; place the remaining probe on the remaining screw. A 3,500-watt element should register 16 ohms, a 4,500-watt element should register between 12 and 13 ohms, and a 5,500-watt element should register between 10 and 11 ohms. Replace the element if it does not register on the multimeter.
8 Leave one of the probes touching one of the screws on the element face. Touch the other probe to any metal part of the water heater. If the multimeter needle moves, the heater element is grounded, and it must be replaced. Make sure you test both screws on the face of the element.
9 Touch each screw with one of the multimeter probes. Place the remaining probe against the metal base attached to the element where it enters the water heater. The element is bad and must be replaced if the needle on the face of the multimeter moves.
10 Attach the wires back to the face of the water heater element. Snap the plastic cover back over the thermostat and the element. Reinstall the insulation and attach the panels to the side of the water tank. Turn the breaker on to the water heater.
Things You Will Need
  • Screwdriver
  • Safety goggles
  • Gloves
  • Noncontact voltage detector
Mar 06, 2015 | Water Water Heaters
Pilot will not light
Please hire the services of a registered gas engineer.
Aug 02, 2014 | Water Heaters
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
Jun 15, 2014 | Water Heaters
Where is the flame sensor?
it will be close to the fire ring and is a photo electric cell
it registers flame light and cuts off the fuel supply with in seconds if the flame doesn't appear
Feb 15, 2014 | Rheem EcoSense by 7.4 GPM Tankless Water...
Registration new water heater
Unknown brand and type water heater.
Tank, hybrid, solar-assisted, indirect, tankless, condensing, gas, electric, under-counter, RV, mobile home, etc?
1) Water heater warranty-coverage does not require registration of product. Usually the registration can take place at manufacturer's site, but not all sites have registration forms.
http://waterheatertimer.org/Water-heater-manufacturers.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#warranty
2) Almost all water heater warranties cover original owner, one-family household installation, when product is installed according to product manual. SO if you register product, then move to new home and take expensive water heater with you, then the registration does not show new address, thereby voiding product warranty because it was relocated.
3) Warranties after first year usually cover parts and tank. Many warranties today are pro-rated, which means longer warranty is becoming almost valueless.
Jan 03, 2013 | Rheem Water Heaters
Can I convert a Rinnai natural gas water heater to LP.
A registered gas installer can obtain parts through Rinnai stockists and convert most heaters.
Feb 22, 2011 | Rinnai Digital Remote Water Heater Control...
Did Ohms check on elements and both upper and lower registered fine. Show power to upper thermostat and upper element but no power to lower element. How do I know it is the thermostat below or the one...
1) All 2-element tanks are 240 volts.
I replace both thermostats
Be sure to put insulation and covers back when finished so thermostats not exposed to cool air that will cause temperature misread.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
2) How thermostats work
http://waterheatertimer.org/How-water-heater-thermostat-works.html
3) You have multimeter, so you're right there.
Take 30 minutes and do complete water heater troubleshoot.
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 15, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rinnai R50LS- water doesn't heat, even though there is good flow.
If it's a new install: the water is going backwards through the heater and you need to check that your cold water IN is actually hooked up to the cold water IN spot on the heater. they don't register flow if the flow goes backwards through the heater.
If it's not a new install: something is stuck in your flow sensor, drain the unit and take it out to check.
Apr 16, 2010 | Rinnai Water Heaters
I recently replaced my gas heater to an electric one now my heater isn't getting hot
check your voltage rating on info plate on unit,agains't what's coming in.confirm wire connection's are 100% at wtr/htr .access the thermostat's and verify,that they are turned up to a set temp,i.e. so low it won't register.a few thing's to look at.good luck.
Mar 31, 2010 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Whirlpool 6th Sense 40-Gallon 6-Year Tall Gas Water Heater Natural Ga Logo
233 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
