Question about Gateway (4000292) Motherboard
NEED HELP WITH SETING UP MY MOTHERBOARD
I DONT KNOW HOW TO SET UP THE FROUNT PANTEL WIRE.
    President:
  • 2,961 Answers
You will need to find the model of motherboard used in your gateway, go to this link for documentation when located the name off the motherboard http://support.gateway.com/support/supinfo/index.asp?pg=2&file=dt_mot.html
Posted on May 14, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
When i turn on my tv its comes up with the set up menu and askes me to press enter - only problem is i dont have a remote please help
use frount panel button it must be place frount or upper side. or left / right side of panel.
Oct 17, 2010 | Televison & Video
Mitsubishi 55" - Stretches screen
on the frount you should have ch up , ch down,
same for volume , and menu. press menu
and scroll down to VIDEO or SET UP
try one of thoes sub menu will have FORMAT
4:3 - 16:9 seting its a little differant on
on same make diferant models , you may
have to do a little hunting to find the setting
Jul 02, 2009 | Mitsubishi WS-55807 TV
I have a 2001 blaster and the rear and frount brakes dont work
Drive your bike to any autozone store and they will show u exactly how to change the brake cable. They will loan you the tools you need and will be there to make sure it gets done properly.
Apr 30, 2009 | 2001 Yamaha TW 200
Dont know where an item should go
This is an internal speaker. Find the speaker pins on the mother board. Should be somewhat close to the front panel connections.
Mar 23, 2009 | Abit NF7-S V2 Motherboard
Motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
kira_ryuk99@yahoo.com
Jan 11, 2009 | ASUS K8V-MX Motherboard
How to remove frount break rotors on 2004 Xterra 4wd
All you need to do is unbolt the front brake calipers and the rotors just slide on and off.
Nov 06, 2008 | 2004 Nissan XTerra
Need to know how to change the clock time?
Push the set button and within 10 seconds press the seek and scan buttons for minute and hour change
Oct 31, 2008 | 2006 Dodge Caravan
Re: lg tower xp install
FDD Floppy-Disk Drive.
It would be advisable to go to the motherboard Manufacturers site. And download the setup or user manual for this Board.
The White or black plastic jumper blocks i,ve refered to, are on the back of the Actual CD/DVD Rom Drive. Located at 1 end. this should be set to Master or Slave. diagram of settings usually printed on top of the drive. I dont know whether you have an IDE Drive ( 40-80 strand ) wire connecter.
Or sata drive connectors. 1 single red cable from motherboard to drive.
please bear in mind, this site is designated to solve technical solutions.
i,ll help all i can, but if your not technical minded, perhaps this is a job for someone more competant than yourself. no disrepect intended.
regards mike @ compurepair.
Mar 30, 2008 | Computers & Internet
Front Panel Audio
I don't believe that this motherboard supports simultaneous front and rear audio. That's the purpose of the jumpers; to route audio to the back panel when on and to the front panel when the front panel connectors are connected,
Jan 13, 2008 | ASUS P4GE-V Motherboard
Gateway (4000292) Motherboard Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
