Question about White Sewing Sew Cute SC20 Mechanical Sewing Machine
The thread isnt moving with the sewing machine
Everything seems to be working fine i replace the needle, now it makes noise moves everything but the top thread isnt moving its not feeding itself threw the needle???? please help.......
  • Elizabeth Tunstall Oct 27, 2012
    Have you tried re-threading it? Sometimes the thread can get caught on it's spool where it's often notched to allow keeping it from un-spooling when stored.  Also, sometimes your thread tension setting can get moved by accident and will be too tight. That is easily corrected by setting it back to "3" or whatever is correct for the fabric you're sewing. Let me know if you've tried either of those. Also check along the thread path to see where the point of "stoppage" is.  Is it loose until you get to the tension knob? Or is it loose until you get to the thread spool? etc.
  • White Sewing Master
  • 7,365 Answers
Is it possible that you didn't get the needle inserted all the way into
the needle holder?
is it possible that the needle is not turned the right way in the
needle holder?
Posted on Oct 30, 2012
  • 5 Answers
SOURCE: The needle won't move ...
www.whitesewing.com try there web site
Posted on May 29, 2007
i_luv_2239
  • 23 Answers
SOURCE: sew easy sewing machine breaks thread
The machine is not threaded correctly, also use medium weight fabric. Check the size of needle. Try a size 14. The bobbin tension may be to tight. If nothing works take it to an expert. After he fixes it make sure he shows you how to thread it.
Posted on Nov 19, 2008
  • 30 Answers
SOURCE: Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Posted on Jan 24, 2009
  • 360 Answers
SOURCE: Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Posted on Feb 08, 2009
louislevel_2
  • 374 Answers
SOURCE: Manual wheel on side of machine won't move needle
hi there;
well try to rotate hand wheel center holder clockwise while hold grift the handwheel not to move to engage the clutch,because ther is clutch that holding the movement of the needle and the bobbins case.if still nothing change at all,open a cover motor assembly chech the belt tension if still engage on pulley,maybe slip pulley is occuring when motor run,if belt is slip to pulley replace belt,but if ok upon clutch adjustment ignore replacement.
regarding bobbin and threading you can watch on youtube.doing this,on internet explorer,type www.youtube.com
then on you tube search type"sewing machine"then click search
ther are high ligthed show for bobbins winding and treading just click it enjoy watching while you learn,have a nice viewing regards
don't forget to rate me,thank's
Posted on Apr 09, 2009
My machine isnt sewing.
We really can't offer much help without knowing the make & model.
Aug 24, 2017 | Sewing Machines
The fabic will not move under the foot feed tried everything !!! Hve the mauels but cant figure this out !!! help and the thread in the bobbin keeps knotting up Thanks
Are the feed dogs moving when you try to stitch? If so, are they below the needle plate so they do not make contact with the fabric? If this is the case, the feed dogs have been dropped to allow darning. Check your manual and raise the feed dogs.
Is the stitch length set to at least 1 1/2 or 2? If the stitch length is set too close to zero, the needle is practically stitching in place. Lengthen the stitch so the fabric will move as the stitch is taken.
Are you sewing very fine material? If the fabric is a very light weight, there may not be enough pressure between the presser foot and the feed dogs. Most machines have an adjustment to increase the presser foot pressure. On newer machines it is usually a dial at the top left of the machine or low on the left side of the needle. Older machines sometimes have a a round cylinder the projects on the top above the needle bar that is spring loaded. Pressing the cylinder down will usually tighten the pressure. Other machines actually have a screw at the top of the needle bar that when screwed down will tighten the pressure.
Nov 22, 2015 | Sewing Machines
Janome hello kitty 525 won't feed fabric or needle does not move up and down. Everything seem to be thread correctly and clean.
Hi Thi: make sure the machine is not set to wind the bobbin. Turn the handwheel towards you and see if the needle moves. You may have a belt that has come off. Does the machine make noise like the motor is running when you press the foot control?
Sep 02, 2013 | Janome Sewing Machines
The needle won't pick up the bobbin thread? Seems
I think you mean the shuttle is not picking up the top thread. There are many reasons why this can happen. The best way to find out which is to leave the cover off the bobbin compartment and turn the machine slowly by hand while watching things happen for a few cycles - best to have a piece of material in place as well (but not in your line of sight).
As the needle begins to rise, the top thread should form a loop for the shuttle to pick up. If no loop forms, the needle could be too fat for the thread, the thread could be sticking to the needle, the pick-up arm could be out of time (unlikely), or the thread tension could be wrong (or the machine not threaded correctly).
If a loop forms, but the shuttle does not pick up up, the needle could be bent (take it off and roll it on a flat surface),or in backwards (loop forming opposite to shuttle), or the material (or your manner of feeding it) causing the needle to be deflected away from the shuttle. On some machines, it is also possible to loosen a clamp and move the shuttle closer to the needle, but obviously that is a last resort (unless it has come loose or been forced away).
There are other possibilities, but usually it's the simplest thing. Try changing the needle?
Jul 27, 2011 | Elna Sewing Machines
Necci Lydia mk2 544. Something seems to be binding. does it need oiling. It only hums when using foot pedal.
try cleaning under the needle plate where the feed dogs are to get out any lint or loose threads
then clean the bobbin area for lint or loose threads
rethread the machine- top thread & bobbin--make sure to thread every thread guide
make sure the thread moves smoothly around the tension dial
also check the top tension setting -usually 3 or 4 is good
make sure the power cord is inserted correctly into the machine
it could also be the foot pedal itself may be going bad--it would have to be checked by a repair shop
always use the same thread on top & in bobbin area
put new needle in also
also some thread & needles are not compatable--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 17, 2010 | Necchi Sewing Machines
My bottom thread is a real mess when I sew. The
I would suggest to replace the bobbin case,
make sure the needle is not in backwards
make sure the needle is not bent
Jul 29, 2010 | Brother BC-1000 Computerized Sewing...
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
Quantum XL-1000
ok it sounds like either the gear on the rotoary hook is bad "lot of money to fix" or there is a small pin that moves the feed dogs make sure it is setted correctly. also make sure the pressure foot is down all the way.
Dec 10, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
White Sewing Sew Cute SC20 Mechanical Sewing Machine Logo
180 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
