Question about Blenders
We have a Barista bar blender from Starbucks maybe 8-10 yrs. the bottom clutch looking gadget came loose and won't engage to blend anymore .are there replacement parts available or who manufactu
Looking for replacement parts for Starbucks Barista Bar Blender Model #181822
  • 1 more comment
  • msanne206
    msanne206 Mar 29, 2013
    Did you ever find the part? I have the same blender and need parts for it.
  • Cindi Flower Jul 13, 2013
    I have the same blender and love it! Now I need a new pitcher. Can anyone help me find it? Anyone have one to sell?
  • murad_cafe Jul 20, 2013
    I have the same blender and can't seem to find a replacement switch. Anyone have any luck ordering parts anywhere for this blender?
SOURCE: stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
Posted on Dec 16, 2007
SOURCE: Durabrand blender model number tsk-9368ap
You just bought a bad blender. Get a different model
Posted on Jul 25, 2008
SOURCE: Can't find replacement parts for my Thunderstick Pro blender
I can sell you part of mine. I getting a new one to replace a part for mine.
Posted on Jun 10, 2009
lucgalman
  • 87 Answers
SOURCE: My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Posted on Oct 06, 2009
Testimonial: "Thanks i just cant find where the sell the parts at but you really helped me!!!"
  • 5 Answers
SOURCE: Looking for a replacement gasket for the VillaWare
If any body needs any parts for the villaware 5785 series I have everything available except the plastic smoothee container. I have some gaskets. If you need it I can send it to you and you can just reimburse me for the shipping after I have sent it to you. You can contact me at amylovescats2010@yahoo.com. Villaware is no longer selling the smoothee container, I doubt if they are selling other parts for it.
Posted on Oct 20, 2009
Need replacement glass for Starbucks blender... Anyone know where to find?
I bought an Oster 6 cup glass and it works perfectly on the Starbucks Barista blender. It has to be the 6 cup NOT the 5 cup or the blade mechanism won't fit. the 6 cup screws right on your old blade base and it was $10 new on Ebay including free shipping.
Aug 14, 2014 | Blenders
Starbucks Glass jar replacement for blender
Feb 20, 2014 | Braun MX2050 Blender Powermax Replacement...
Replacement glass jar for 2003 Starbucks blender
Feb 02, 2013 | Braun MX2050 Blender Powermax Replacement...
The blender has a film on it, it's not clear anymore like the dry blender
Depending on what you are blending, the glass can become scratched. Nut shells, coffee beans, some grains will scratch glass and make it look like a film.
Otherwise, it it is a film, you can try soaking it in ammonia if it is soap **** (from low-priced or "natural" soaps used in hard water.
Or soak in vinegar if it is lime from hard water (usually from letting it air dry after washing and rinsing well). Try rinsing in cold water after the hot water rinse to prevent water spots.
Sep 09, 2011 | Vitamix 5200 VariableSpeed Blender
Oct 06, 2009 | Kenmore Blender Single-Speed Blender
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
KITCHENAIDE BLENDER
sounds like you engage gogs under you canister are slipping or wore out lift up your canister to check them. not sure if your particular model has set screws in them or not look and see might be it hope this helps
Sep 01, 2008 | KitchenAid KSB5 Professional Stainless...
Jul 10, 2008 | Blenders
I have the tsk-9368ap blender model. Before I blend, I lock the blade in place on the bottom, while I am blending the blade comes loose, and whatever I am blending starts coming out of the bottom, I'm not...
kalexis - there is no such thing as support for the Durabrand TSK-9368AP - Wal-Mart decided that the products were so cheap that people would buy a new one if it broke. What I would do is take your blender into an Ace or True Value Hardware store, and have someone find a generic gasket that will fit your blender.
sheens1953 - the seal/gasket for the Smoothie Maker Elite can be found here:
http://www.focuselectrics.com/finditem.cfm?itemid=4308
-Tha Mp3 Doctor
Jul 10, 2008 | Back to Basics Smoothie Elite Work Top...
Stopped blending
May 17, 2007 | Waring PBB 25 Professional Work Top...
Blenders Logo
1,253 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
