How to connect my hp pavilion 7915 desktop to a wifi network ?
  • Computers & ... Master
  • 5,129 Answers
The HP Pavilion 7915 will need a wifi network adapter card to connect to a wireless network. You would need to add an wired network interface adapter card to use a wired network, instead of a dial up connection. Check the height of your computer - a "Low Profile Card" may be needed. There are several versions of the 7915.
You can get a USB network adapter or a PCI slot card for either type of network from most computer stores. Depending on which version of the 7915 you have, you may have a limited number of USB ports. In that case the PCI card may be a better option assuming you have an available slot. Other models only have one PCI slot which can be blocked by a VGA card.
What OS is on your computer? I see some models shipped with XP and others with an older version of Windows. You will need to find a card that has drivers for your OS. Finding XP drivers will be easier than those for the older versions of Windows. Depending on the unit you order and your OS, the drivers may be already be installed in the OS. In that case, plug it in and go.
If you go with a PCI wireless network interface card, turn off the computer and unplug all of the wires before opening your case. Ground yourself relative to the computer by touching a metal part of the case before continuing. Remove the slot cover screw (hex head with a Philips slot) (for most desktops) from an available slot. Push the section of the card with the gold contacts fully into the slot. Work carefully and keep the slot section of the card between the case and motherboard. Press firmly and make sure that the card is level all the way across. Then screw the slot bracket down. (Note: you could remove the fax/modem instead of the cover if you do not need the modem.)
For a USB interface option, just plug it in. When the drivers are installed (follow the directions), attach the wifi antenna (if needed). Try to identify available networks (in XP click Start > Control Panel > Network then go to the network wizard to add a new network). Use the network ID and password for your wireless router. (I assume there are other wireless devices and the router has been set up; many older models need to be attached to a computer via a wired ethernet port for the initial set up. Most models have an initial name and password that should be changed.)
I hope this helps. If you have additional questions, please provide more information about your computer's OS and available expansion options. Also indicate what router you are using.
Posted on Oct 28, 2012
simplemitch
  • 752 Answers
SOURCE: hp zd8000 vista wifi problem
Is your WLAN turned on? It's usually a switch or button somewhere on the machine with the WiFi icon around it. Kind of like this:
(( i ))
Posted on Aug 05, 2008
  • 211 Answers
SOURCE: WIFI not working
Send it back to HP, they will fix it even if its out of warranty:
HP Limited Warranty Service Enhancetment.
Posted on Mar 12, 2009
  • 334 Answers
SOURCE: swapped hard drives, wifi doesn't work now.
Hey there, go to the following link and tr to reinstall the driver. just enter your model numer (ie dv9074cl) then enter your operating system then it will bring up every driver for that laptop. Make sure you blow out the top left corner slots with canned air on a regular basis with these hp's or they will overheat and eventualy fail. Very important, the are notorious for this. Let me know if you need any thing else
seth
Posted on Jun 27, 2009
  • 184 Answers
SOURCE: I was able to connect
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Posted on Sep 25, 2011
puertobori
  • 7733 Answers
SOURCE: I have a hp Pavilion running mac os x snow leopard
Go here
Posted on Oct 02, 2011
I have a hp pavilion 515n desktop computer and was wondering how to get the password for the wifi.
Hi Ettajean,
The wireless password can be located either on the wireless router itself (if it's being provided to you by your ISP), or you'll need to log into your router to view/change your wireless password.
If you've connected to the wireless router before and simply need to recall the password, you can view it inside of Windows:
http://www.microsoft.com/surface/en-ca/support/networking-and-connectivity/how-to-find-your-wireless-network-password
If you can post the model number of your router, I can provide you with some additional direction.
Hope this helps!
Mar 01, 2015 | HP Pavilion 515n (DC471A#ABA) PC Desktop
Wifi connection fail
you may be are far from the access point device or your password may be incorrect.
Feb 06, 2014 | HP Pavilion a1430n PC Desktop
Wifi on hp pavilion 7915
After looking at the specs for this machine:
Model number
P1062A
Processor
Intel Celeron 1GHz
Chipset
Intel 815b
Bus Frequency
100 MHz
Memory
  • 256 MB SDRAM / 133
  • Two DIMM Slots
Storage
  • 20 GB Ultra DMA hard disk drive
  • CD-RW 12x8x32x rewriteable drive
Communication
  • 90 K56 PcTel Modem
  • Network Interface (integrated) 10/100BT
Video
  • Integrated into Intel chipset
Sound
  • Integrated AC97 Audio
  • Two Polk Audio premium stereo speakers
Accessories
  • HP Internet Keyboard
  • PS/2 Scroller Mouse
Ports and expandability
  • Five expansion bays (free: 1 - 5.25 external, 1-3.5 internal)
  • One AGP (free)
  • Three PCI (one PCI free)
  • Four USB (two in front)
  • One parallel port
  • Two serial ports (one in front)
Complete software package
Supported operating system
Microsoft (R) Windows Millennium Edition
Productivity
Microsoft Works Suite 2001
  • Microsoft Word 2000
  • Microsoft Works Standard 2001
  • Microsoft Encarta World Atlas 2001 (English version)
  • Microsoft Picture It! Photo (English version)
  • Microsoft AutoRoute Europe 2001 (English version)
  • Microsoft Internet Explorer 5.5
  • Microsoft Outlook Express
  • Smith Micro QuickLink III (fax)
  • Adobe (R) Acrobat (R) Reader
Internet and online
  • Free2Connect
Service and support
  • HP Pavilion Online User's Guide
  • HP Help
  • HP Tour Guide
  • HP Pavilion Recovery Kit
  • ActiveShield PC Clinic by McAfee
Entertainment
  • Adaptec Direct CD, Easy CD Creator and UDF Reader
  • MusicMatch Jukebox
  • ArcSoft "My Photo Center
It appears that this machine does not have a wifi network adapter. You will need to buy / install a wireless adapter for this machine so you can connect to a wifi network.
Oct 27, 2012 | HP Pavilion 7915 PC Desktop
HP Pavilion dv9700 laptop, Wireless stops working at random.
HP's normally use the Atheros wifi card which recently has had many problems such as what you describe here. Try a different wifi card to see if this solves the problem. If you don't have a wifi card take it to a local repair shop to see if they have one they can try for you.
Sep 23, 2009 | HP Computers & Internet
WHAT PCI CARD TO GET WIRELESS INTERNET ACCESS ON
You can get this adapter from Linksys its WMP54G so you can make the computer wireless, but you can also check some adapter from Ntegear , Belkin and Dlink...
Aug 16, 2009 | HP Pavilion 734n PC Desktop
Trying to help girfriend in Italy connect HP Pavilion dv6810el to the internet
first make sure the wifi is installed properly through device manager in system menu in control panel
secondly make sure the wifi is ready to connect to any through network connection in the control panel
Oct 03, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
