Maytag epic mfw9800tqo door won't unlock
Door won't unlock received f11 error, hit cancel button. door won't unlock and when unplugged for 15 minutes and plugged back in it still won't unlock and won't start new cycle.
  • 3 more comments
  • Rob and Marlene Bond Oct 30, 2012
    we found how to open the door. Now when we press the on button, select cycle, and press the start buttonthe start button won't turn the washer on. Our washer is mfw9600sqo not the one I thought it was I couldn't get to the model number until we opened the door. Please help.
  • Richard Roth
    Richard Roth Oct 31, 2012
    Check all the connections on the "control board". If all connections are good, you will need to replace the control board. Here is the part to order. http://click.linksynergy.com/fs-bin/clic...
  • Richard Roth
    The 9600 is famous for the control board going out.
  • Rob and Marlene Bond Oct 31, 2012
    Thank you for helping us. I will definitely start checking the connections. I appreciate you giving me the manual and the link to the part. Your helping is such a blessing. TY!
  • Richard Roth
    Keep me posted!
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Here is the complete service manual for that unit.
Posted on Oct 31, 2012
Testimonial: "Thank you so much. I greatly appreciate it! Take care. :)"
SOURCE: F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Posted on Sep 09, 2008
SOURCE: washer flashing 02 F
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Posted on Jul 18, 2009
catriver
  • 878 Answers
SOURCE: Oasis - DU and LF error codes
Ky, see if you can put the machine in the service mode by doing this: turn the washer on, select any one button except for power,start and stop. press and hold it for 3 seconds--release for 3 seconds--press and hold for 3 seconds--release for 3 seconds--press and hold for 3 seconds....if you entered it correctly all the indicators will light for 5 seconds and 88 will show in the 2 digit display..It will now go into a automatic test cycle. If no faults are found it should unlock the top. This auto test will go through c0 to c9, you will see it in the display. If this all fails, you can access your wash by pushing in the clips on the left and right side front of the washer lid. The whole top will lift up. I would still call for service while it's under warranty. Catriver...post back.
Posted on Sep 11, 2006
SOURCE: error code F dL, then F11
F/DL is indeed a door lock error. I had this on my machine, did a lot of research and getting some idea of how it works. The code is generated when the CCU can't lock the door. Possible causes are door latch mechanism, connecting wiring, or the CCU. I could hear clicking from the CCU on my machine which indicated to me the CCU was trying to lock the door. It tries 6 times before setting the F/DL code. I tested the latch and wiring from the CCU - OK. The clicking I heard had to be relay(s) so I figured the problem was relay contact failure. I removed the CCU board, determined which relays were suspect (there are two for lock & unlock). I changed them both and saved myself spending $300 CA on a new CCU. The relays cost just over $2 each. I found replacement relays @ Electro Sonic (www.e-sonic.com; minimum $25 order plus shipping $7.50). Relay made by OMRON part # G5LE-14-DC12 replacment for original G5LE-1-VD 12VDC. I'm not impressed to have to change a $300 CCU because of a $2 relay failure. For me this was worth the try as I have some experience working with circuit boards. The relays would be a quick repair for anyone with similar experience. Hope this helps someone.
Posted on Sep 16, 2007
SOURCE: Maytag Epic Z washer F1 error
The F-01 problem is a computer board error. If you have warranty, call them up and they'll replace them for free. If not, I think it's going to be pretty expensive...
Posted on Jul 13, 2008
Door woont open
make sure it is OFF. hit the cancel button. it won't open if it thinks it is in a cycle.
Sep 02, 2012 | Maytag Washing Machines
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
I would like to know how many gallons of water this machine uses per washload. Maytag Epic Front load Washing Machine Model # MFW9800TQO
Around 5 gallons per FiLL more then 1 fill per cycle add up all the fills for the cycle that you use..that will give you the total water used...hope I helped thanks for voting...
Mar 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
I hit cancel in the middle of a cycle and now it keeps saying F1
From the maytag website:
To remove the error display, press Power/Cancel or Pause/Cancel twice.
If Power/Cancel or Pause/Cancel does not work:
Re-select the cycle and press Start/Pause.
Sep 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
Jun 15, 2008 | Washing Machines
Washing Machines Logo
490 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
