Question about Music
Yamaha PSR-240. Mechanical sound
Mechanical sound when i press on the key
    Genius:
  • 1,212 Answers
Deformed metal contact will also add a slight resistance to it. You may have some dirt or grit in there, or a plastic pivot may have broken.
Vaccuum it first while pressing key or affected keys, and then apply something like LPS1 (which makes an excellent contact cleaner) If that does not clear it up, go the opposite direction with compressed air while moving the key or affected keys.
If that does not clear it up, you may need to diassemble the key to find the source of the noise and address it that way.
Posted on Oct 28, 2012
  • 1138 Answers
SOURCE: yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
Posted on Jul 24, 2009
  • 1121 Answers
SOURCE: 3 keys don't work on my Yamaha PSR-150 keyboard.
yes. you must change keyboard pad, below the keys, and check for dirt and deteriorated board.
Posted on Oct 30, 2009
  • 88 Answers
SOURCE: 3 keys non function on Yamaha PSR 3000 sometimes
rubber contact strip requires replacement
Posted on Feb 05, 2010
  • 5603 Answers
SOURCE: some of the keys do not play on our Yamaha
The key contacts have gotten dirty. The contacts are CONDUCTIVE rubber pills that are pressed onto circuit traces on the circuit board under the keys. Onehas to dis-assemble the keyboard very carefully noting the size and location of all the screws and using great care of the cables that connect the top and bottom of the case.
when you remove the keys, you will find silicone rubber strips with the black pills underneath, two pills per key.
Clean these with ONLY 99% isoprophyl alcohol and Qtips as well as cleaning the circuit board traces they contact.
Carefully re-assemble the keyboard.
Posted on Jan 09, 2011
  • 5603 Answers
SOURCE: I have a yamaha PSR 240 and one of the keys (E)
Yep, a key contact has got contaminated... You have to disassemble the unit to expose the keys.
You have to remove the offending key which is OFTEN tied to a bunch of keys. Under the keys you will find strips of silicon rubber with little domes sticking up. Under the domes are two contacts, either two black conductive rubber or sometimes a ring with a pill in the middle. These contact circuit traces with a black coating on the board under the keys. Clean the pills AND the circuit traces GENTLY with ONLY 99% isoprophyl alcohol. Reassemble the keys and the unit.
Be very careful handling, especially the ribbon cables between teh upper and lower halves of the unit.
Note there are TWO contacts per key which one closes before the other and that is how the key velocity is measured by the processor.
Posted on Feb 12, 2011
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
How do connect the yamaha psr-e243 ypt-240 to a computer
use the midi output..but you have to use a midi sound card and softwares like qbase
Oct 05, 2014 | Yamaha Music
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
Model: PSR 620. The floppy drive is not working and needs to be replaced. Original floppy drive uses DS DD 720kb floppies. Where can I get a replacement drive? How much does it cost?
The replacement cost of these is prohibitive often greater than $200.
You should try to clean the heads in your drive and see if you can spot a mechanical problem. Clean the heads carefully with 91% isoprophyl alcohol and Tube Gauze on a tongue depressor. Be very careful.
Aug 09, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha psr 400 give an Er 1 message when switched on and gives no sound when played. The demo works however
Wild guess of possibilities.
1. Internal backup battery exhausted.
2. Button OR key is stuck down, either mechanically or electrically.
Jan 06, 2010 | Yamaha Portable Keyboard with 61...
Psr-60 serial no 008012
Yamaha PSR 60. Power light comes on but no sound from any of the keys or anything else. Can anyone advise
Jul 28, 2009 | Yamaha Portable Keyboard
Yamaha psr-240 lights up but no sound.. no sound from head phones either. Seems to be working with exception of sound out..
try placing your ear on the speakers, adjust the volume control up and down several times, you should hear a humming sound that goes up and down. if not problem with the stage before the amplifier, that is the sound processor. if you dont hear the hum. problem with the amplifier and speakers, including the sound ports or jack. dissassemble the unit. look for loose connections from speakers to amplifier.
Jul 14, 2009 | Yamaha Portable Keyboard with 61...
Music Logo
63 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
