Question about Tachikara TPE-33 Replacement Hose for Electric Ball Compressor
Manual for tachikara TPE-33
I need the manual. I think the switch is bad and would like to order a new switch.
    Genius:
  • 1,212 Answers
If you can disassemble the switch housing assembly, normally those switches themselves are available from various sources for a great deal less than the assembly. That rocker switch is cheap to begin with and if you do not have a local radio parts store, you can order a comparable or better quality switch that pops right in from Digikey, or Mouser. Digikey ships globally.
If nothing else- locate a scrap coffee maker, or scrap computer power supply with a similar sized (physically) switch and just pop it out, and replace that one on the compressor. You can compare the current and voltage rating on the side of the switch. If the replacement happens to have higher ratings- the longer it will last.
I always keep a bunch of used and new stock switches like that on hand.
Posted on Oct 28, 2012
Oster 3309-33 user manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Oster model by clicking the link below.
https://www.manualslib.com/manual/816334/Oster-3305-33.html#product-3309-33
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 17, 2013 | Oster Coffee Makers & Espresso Machines
1997 ford contour tail lights won't work but brake lights do already changed bulbs what fuse is for parking light
There are 2 fuses,left and right, so I dont think both could be out? fuses. 33 and 35. make sure they have power on both sides of the fuse. If one side has power, its blown, if no power, the headlamp switch is bad, or bad connection. The RED/BLACK wires coming out of the headlamp switch go to those fuses. 33-35
Dec 10, 2010 | 1997 Ford Contour
Punctured inner bladder Tachikara SV-5 volleyball
Fix A Flat. Screw the needle valve into the noozle of a can of Fix a Flat. Squirt enough in to inflate to normal pressure, Roll the ball around to coat the inside. Blow the needle valve clear afterwards attached to a bike pump.
Jan 30, 2010 | Sport & Outdoor - Others
Starview telewest codes 21/01/2010
Telewest last updated 12/10/09
00 CF 53 OC 33 79 61 71 85
01 52 5E 8D 45 FC 75 F6 4A
NO CHANGES YET.
Jan 21, 2010 | StarTech.com StarView SV211K 2-port KVM...
Keboard will ot tpe soe letters
Use the following link to remove keyboard. Once you remove remove the keyboard plug it back in and follow the instructions in reverse to put the keyboard back. If that doesn't work you more than likely have a bad keyboard and it needs to be replaced. If it is still under warranty call dell and they can send you a new one. If it isn't under warranty then you call dell and buy a replacement.
http://support.dell.com/support/edocs/systems/latd600/sm/keyboard.htm#1111863
Sep 13, 2009 | Dell Latitude D600 Notebook
I bought a Sony SVO-9500 MDP VCR witout the manual, cannot get a manual anywhere!!! I wish to now the menu commands tPE SuH Cnr Ynr YEn FrE uIA FOT Please help, what do they mean!!!??? Thank...
Settings are described in the manual downloadable now at www.eserviceinfo.com
From the manual
tPE = tape end operation mode REwind/EJect/STop
SuH = SVideo selection AuTomatic/OFf
Cnr = Chroma noise reducer ON/OFf
Ynr = Digital luminance noise reducer ON/OFf
YEn = Digital Y enhancer ON/OFf
FrE = Freeze mode selection FRame / FIeld
uIA = VISS index marker ON/OFf
FOT = Foot Switch Operation LowEdge HighEdge LowLevel
Hope this helps
Mar 11, 2009 | Televison & Video
B and O beogram 1700
Problem might be the 33 switch. If it's gone bad, it will cause this kind of problem. The issue is not the motor. Possibly one of the capacitors or resistors might have gone bad. Not easy to determine without the proper tools and a service manual.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Jul 26, 2008 | Audio Players & Recorders
Tachikara TPE-33 Replacement Hose for Electric Ball Compressor Logo
90 people viewed this question
Top Tachikara Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Tachikara Air Tool and Compressor Expert? Answer questions, earn points and help others
