Question about Canon imageCLASS Office Equipment & Supplies
I HAVE A PAPER JAM ON A CANNON IR1570F COPIER
SOURCE: CANNON SUPER 63 IMAGE RUNNER 1370F PAPER JAM
It is hard to tell where the paper is with out seeing it or looking at the jam log. start by looking for green. On canon green is for jam removel if you see a green tab lift it, if you see a green knob turn it. good luck
Posted on Jan 12, 2008
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
namizhka
  • 148 Answers
SOURCE: Copier canon mf4150 says it
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Posted on Sep 16, 2008
MXM450
  • 62 Answers
SOURCE: Paper Jam Cannon Image class MF6550
its the registration sensor flag... change it.
Posted on Jan 24, 2009
SOURCE: Copier - Paper does not feed/paper jam light keeps going on.
Depending on the type of machine, it is probably just dirty rollers that pick up your paper (slipping). If you remove the tray, and look inside you should see some rollers (usually gray) that take the paper from the tray. Use a cloth dampened with some alcohol(if you have it) or simply water to clean these rollers (gently).. dry if you have used water, the top sheet or 2 of previously used paper, and try it.
Posted on Feb 16, 2009
I have d760 cannon copier. finally removed the
hi,
Check to see if there is paper in the fuser unit, it does consertina in it. I wood use a torch because these are difficult to see without a torch. Take the left covers off to see better.
Good luck
Oct 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Hi, I have an e20 cannon copier. There was a paper jam, the paper was removed and then when I go to restart the copier it still has that paper jam icon showing. I looked everywhere in the machine and there...
Hi, I solved the problem. I had another employee look it over and there was still a teeny teeny piece of paper that was still jamming it up. So once that was removed the copier started working okay again. Thank you for taking the time to try and help me. Sould I encounter any other copier problems I'll get back to you.
Oct 12, 2009 | Canon Compatible Toner Cartridge Replace...
COPIER WONT COPY AS LITE INDICATES PAPER JAM DON'T SEE ANY PAPER AT ALL
Hello sir; Go back to wherever you pull out the paper, because you pull the paper in opposite direction therefor pull off the senser,go back where the paper jam put the senser back in right position.
May 30, 2009 | Sharp AL-1655CS Copier
Jan 13, 2009 | Canon imageCLASS MF6550 Monochrome Laser...
My cannon super 63 image runner 1370f
look on the control panel if there is a diagram of your printer it will usually light up the area where the paper jam is located.
once you find location of paper jam there is normally a green knob in the area of jam that when you manually rotate it will release paper also open paper drawer check for jam or unplug and plug copier back in somtimes this will force paper out as it resets
Jan 13, 2008 | Canon IMAGERUNNER 6570 Copier
Jan 12, 2008 | Canon IMAGERUNNER 6570 Copier
Cannon image class d761 copier
Check under the toner cartridge for the jam.
If this help you, please rate me. Thanks, Patty
Dec 28, 2007 | Canon imageCLASS D761 Copier
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
114 people viewed this question
old marine
old marine
