Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
How to replace cord wrap on hoover windtunnel
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
reddevil6
  • 1673 Answers
SOURCE: repplacing power cord on Hoover Wind tunnel (not self propelled)
I am thinking that the cord goes in on the back, just below the handle. Remove the handle, then from the front, remove the tool holder(#8), then you can get to where the cord comes in and hooks up.
Posted on Feb 12, 2008
SOURCE: replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Posted on Aug 08, 2008
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
  • 8 Answers
SOURCE: Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
Posted on Oct 25, 2009
Replace power cord on Hoover windtunnel vacumm
There are many different models of Hoover Windtunnel so I can't be specific to your model, you will need to determine where the cord enters the unit and how to gain access to the internal wiring. Disconnect the old cord and attach the new cord using the proper connectors.
Apr 02, 2017 | Hoover Vacuums
The bottom cord wrap piece broke off. How do I remove it? I have the new part.
There are little prongs on the end of the cord wrap that expand when pushed into the hole in the vacuum. I've used a small screwdriver to push on the tabs to get the old part out.
Dec 21, 2015 | Hoover U5750-900 WindTunnel Bagless...
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
Hi there! We recommend taking your vacuum to a Hoover authorized service center to have your cord repaired. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Oct 13, 2014 | Hoover Windtunnel Supreme U5280-900...
How do I replace the Hoover Upper cord Wrap?
Do you mean the holder? Contact Hoover with your make and model and see if they can send you a replacement. But I doubt it. Try glueing it back on if you still have it. Use a good epoxy glue.
Oct 12, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Need instructions to replace hoover U5757-900 belt
install the belt on the motor shaft first by sliding it sideways between the shaft and housing. then install on the brushroll and stretch in place
Mar 06, 2010 | Hoover U5750-900 WindTunnel Bagless...
Can i fix a chewed apart cor on a vaccum cleaner or do i need to replace cord
fix it!! with it unplugged, strip both ends of the chewed area to bare wire and then splice them back together. Wrap the splice with electrical tape!
Dec 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
I need to replace the cord wrap part that flips up to retain the cord and down to release the cord and can find the part to order one.
you can locate your nearest dealer through the Hoover web site and then call them to order you one. once they have it in you could take the vac to them for the cord hook to install for you.
Oct 26, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Need to replace cord on hoover u5720
un do all screws on back of vac replace cord screw back together
Feb 11, 2009 | Hoover U5720-900 WindTunnel Upright Vacuum
Replacing power cord
I replace one on my U6439-900. I took the back cover off and had to cut the wires and put new wire nuts on. Then I secured them really well with electricians tape. Might help to even put on a zip tie around the wiring. Hope that helps.
Jul 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
53 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
