Question about Troy-Bilt Troy-Built Gas String Trimmer TB32EC
How do you replace the fuel assembly in a troy built weedeater? I have the new parts.
  • Troy-Bilt Master
  • 7,482 Answers
How do you replace the fuel assembly in a troy bui - 10_30_2012_8_50_42_pm.gif
Hi Clayton
Hope this is what your looking for
Bud
Posted on Oct 30, 2012
  • Clayton Crosley Nov 01, 2012
    Thank you Bud it was perfect for the solution!
  • Curtis Sewell
    Curtis Sewell Nov 02, 2012
    Your welcome Clayton...glad it was what you needed
Looking for diagram to replace key way in Troy built 190 cc mower
they keyway is part of the crankshaft. i suspect you mean the key itself?? should be easy. remove engine cover, remove flywheel, replace key and reverse assembly
Jun 22, 2017 | Troy Garden
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Why does my weedeater start then it just stops running
sounds like the diaphragms in your carb need replacing. and clean your carb at the same time
Jun 05, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
How does one adjust the carb on a TB22EC
I have replaced the entire carburetor, rear case o ring, spark plug, and fuel lines on this same weedeater and can't for the life of me even get a fire.
Apr 26, 2012 | Garden
Troy built weedeater 70ss gas engine will not run
The needle and seat (esp. the needle) meter the amount of gas/oil that is being allowed into the metering chamber of the carb for use by the engine. Your problem does seem fuel related. These carbs are very temperamental and scare most folks. A guide to how they work can be found here: www.zamacarb.com/pdfs/TechGuide_2007.pdf
This will give you an understanding of what exactly you are dealing with. You may only require a diaghram kit or rebuild kit to get the carb back to the functionality it was designed for. That info can be found here once you know your carbs exact model number.
http://www.m-and-d.com/zama_carburetor.html
A troubleshooting guide for these carbs is included in the first pdf file, look it over maybe and see what you think. Post back maybe later after going to school (doesn't hurt to learn how they work). We will be here. I know you want to use this machine (its the growing season) but there are so many things that can be wrong that it needs to be narrowed down...sounds like fuel starvation and just may need to clean the inside of the carb with something like the brake parts cleaner spray. It is non-flammable and doesn't damage the sensitive parts inside these carburetors the way ehanol and harsh carb/chokle sprays and strong solvents due...NEVER soak these carbs in a "Gunk style" carb cleaning tank....it will seriously damage sensitive internal parts and check valves!
Jul 10, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do I change the trimline for my weedeater?
If you go to the troy built site you can download a manual for your model. I is in pdf
May 18, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt Troy-Built Gas String Trimmer TB32EC Logo
276 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
