Panasonic N2qayb000479 remote not working
Remote was playing up so batteries were replaced. Remote still didn't work properly and finally stopped all together
5 Suggested Answers
  • 6 Answers
SOURCE: dvd remote stopped working
open up your remote then separate the rubber / key pads then clean the cercuit using home dry cleaner and leave to dry close your remote gently and its fresh again. reason for this is practice is because moist cause cover between pads and circuit board and thus no contact then no function
Posted on Jul 27, 2007
  • 7 Answers
SOURCE: Keyless Remote Doesn't Work
http://www.programyourremote.com
Posted on Mar 04, 2009
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Posted on Mar 11, 2009
SOURCE: MWD2205 remote stopped working for DVD functions
not sure but it sounds like you need to push the dvd button itself before dvd functions will work-it's to the left of the pause button. same thing happened to me and when i try that it works. remote seems to default to vcr i guess ....
Posted on May 13, 2009
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
My remote for sony dvd player NS 590 p suddenly stopped working. I repleced the batteries but it didn't help
if its not batteries it will be a replacement remote. try cleaning the terminals and see if helps,
Dec 10, 2011 | Televison & Video
I have a 32" insignia LCD TV. My remote stop
You can reset your remote control by removing the batteries, pressing all of its buttons, and installing new batteries. Also, ensure that your TV's sensor is clean and unobstructed. If the problem persists, try using a universal remote control as a troubleshooting step. This will help identify whether the original remote or the TV is at fault.
Oct 20, 2011 | Insignia IS-LCDTV32 32 in. Television
MY TV REMOTE IS NOT WORKING ?
Check the battery of your remote.Try to replace new battery.If didn't work.Try to open and clean the contact of the bottun of the battery.If didn't work, its need to replace the crystal of the battery.Try this sugestion.Thanks
Aug 26, 2011 | Sony KDL32EX700 32 in TV
My remote won't set to the tv I tried pressing the set button and it didn't work then I replaced the batteries to see if that would work but it didn't and now I don't know what to do please...
Hello
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
Jul 21, 2011 | Vizio VF552XVT 55 in. LCD HDTV
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR-EX88 recorder was working fine but remote has stopped working so cant get to the hard drive (can still play a disk by pressing play on the unit). Remote started working intermittently, now...
Either the remote itself is exhibiting strange behaviour, or the unit's IRD controller circuit (and/or the IRD itself) is faulty. Perhaps when you changed the batteries, the remote needs to be 're-commanded' (that means entering a remote code by pressing and holding 2 buttons together for 10 seconds - example - 1 + ENTER/OK) - this should be done whenever the batteries are replaced. If this does not restore the remote to full control, then the IRD (and/or its controller circuit) is the most likely suspect; or, worst case scenario; your remote is defective. I hope it isn't the latter.
I suggest you submit the unit to an authorised service centre for a quote (since this is not a disc drive replacement/alignment it shouldn't be too expensive) then you can decide for yourself afterwards as to what further action to take. Up to you, it is not unfixable. You can always ask Panasonic directly for straight answers and get a second opinion at the same time.
I hope you do not need a new remote at this stage.
Apr 01, 2011 | Panasonic DMRES20D DVD Recorder
Remote control has stopped working
If you have replaced the batteries with KNOWN GOOD ones, observed the proper polarity when re-installing the batteries AND made sure the remote is in DVD "mode" (if it is a multi-remote) when trying to use it, the remote is bad. Replace the remote.
Mar 25, 2009 | Panasonic DMRES15 DVD Recorder
Re: Panasonic Remote Control for DMR-ES35V
All you have to do is unplug the power cord from the unit, wait 10 seconds, and plug it back in. The reboot will make your remote work again. Actually, it is the UNIT that is faulty, not your remote.
Jun 25, 2008 | Panasonic DMR-ES35VS
Televison & Video Logo
482 people viewed this question
Top Televison & Video Experts
Electro Med Services...
