Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
KitchenAid 24 in. KUDI01 only cancel drain works
2 Suggested Answers
SOURCE: KitchenAid 24 in. KUDI01TJ will
http://www.applianceblog.com/mainforums/kitchenaid/17513-fixed-cancel-drain-light-flashing-not-working.html
Hi it's hard to diagnose from symptoms described, but try this post and fix below i am pretty sure this may be whats happening with your unit? Please read right through to the bottom....
Posted on Jun 18, 2011
Dishwasher was not draining. I cleaned out everything and now it wont start
I have the same problem with another Kitchenaid model. I've had better results at keeping the water drained by running two back to back water saver cycles than running a full pots and pans cycle.
Nov 06, 2017 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kitchenaid kud101tj "cancel drain" light and "Rinse Only" lights are falhing and DW won't start???
Don't know if this will help, but when I had problems with my control panel (lights blinked and nothing worked) I fixed it by disconnecting the power completly from the dishwasher at the fuse box. Leave it off 10 or 15 minutes and then repower. That reset mine and it worked again...has happened several times and each time I could fix it by cutting the power. If that doesn't work, you may need a new control panel.
Sep 11, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 05, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
KitchenAid Normal light stays on
check to see if its a draining problem,blockage under the sink etc ive not worked on this brand before.hope this helps.Ian
Mar 19, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher won't drain
cancel/drain button doenst work??? reomove the drain haose from under hte sink and look for a clog right there.
Mar 18, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Cancel / drain
Sounds like the membrane switches have failed-- very common for the new computer controlled appliances. I believe it will be sold as a whole new top console available at all appliance parts retailers or www3.sears.com
Oct 14, 2007 | KitchenAid 24 in. KUDM01TJ - Multiple...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
54 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
