Question about Maax Home
The touch screen doesn't turn on
Is there a reset switch on the motor
  • Ginnie Oct 29, 2012
    All fixed
    Top Expert:
  • Maax Master
  • 77,194 Answers
This is a Bathtub?
Posted on Oct 29, 2012
Whenever I switch on to start operating, during my waiting to warm up, it displays error code C-D369. and it doesn't function from there.
Error code reset:turn OFF the copier ,press and hold the Utility key to right hand,to left hand turn ON the copier,wait appaire on the display Trouble reset,touch the screen and turn OFF the copier.Wait 2 minute and turn ON.
Jan 17, 2013 | Konica Minolta bizhub C250 All-In-One...
Doesn't turn on
Gain access to the electrical connection with voltmeter set to 110 v ac check for voltage on both sides of switch. If voltage is present on outlet side follow output wire to start relay ck for power on out put side of relay. if power follow output wire to motor if voltage is present replace motor ! Be careful where you touch when probing contacts !
Dec 29, 2012 | Kenmore whispertone 100 model 116
Screen doesn't work
Try turning the phone off and remove the battery. Wait about 30 seconds or so and put the battery back in and turn it on. This is one way to reset phones or devices with removable batteries.
Sep 18, 2012 | T-Mobile HTC MyTouch 3G Slide...
Iphone 3gs screen problem
If the problem is consistent in other windows besides strictly the keyboard it is possible that the capacitive touch panel is defective or has been damaged.
Dec 12, 2011 | Apple iPhone 3G
The touhscreen is not working properly. I touch Change State and it takes me to Postal code with the letter pad. I touch 123 and it enters a letter. The erase button does not erase. Every button I touch...
with unit off slide the power switch to the Left as to power unit on BUT HOLD the switch to left about 30-45 sec then you should see the calibration screen. Tap the corresponding taps very lightly and use a pencil eraser to be more precise with your touches.
Sep 25, 2011 | Garmin nuvi 255W GPS Receiver
Touch screen for definition only works when I turn on the ereader and after that when I touch the screen for definition it doesn't work. It turns the page instead.
Hi Darnellakell!
I´m not sure if you already tried to reset the reader, turn it off, and hit the reset button at the bottom of the reader then turn it on. Just make sure the reader is fully charge, your books will not be affected =)
You can check this forum and ask your questions too =)
http://digialreader.freeforums.org/prs600-f8.html
Jul 03, 2011 | Sony Reader Touch PRS-600
Ignition starts and clicking sound is strong but motor doesn't turn
Simply a weak battery would be the first logical assumption, then lose wires, or cables, after the the solenoid on the starter. If you have jumper cables see if you can jump start it hook up the positive or red cables to both battery's first then the negative. Pay close attention not to touch them together and not to hook them up backwards on one and correctly on the other you will damage your wiring system, battery, etc. Hope this helps.
Jun 14, 2011 | 1998 Toyota Avalon
The touch screen doesn't work
here are various problems the lg ks660 touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Press and hold the home button as well as the reset button on the top of the lg ks660 phone to turn the lg ks660 off.
May 09, 2011 | LG KS660 Cell Phone
I have dropped my phone and now the touch screen doesn't work how do i reset my phone when the touch screen doesn;t work
if your phone's touch screen has not developed any cracks, it could have damaged the touch interface internally, i would suggest getting your phone checked at nearest Samsung authorized service centre
May 09, 2011 | Samsung Wave S8500 Smartphone
Home Logo
138 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
