Question about Kenmore Dishwashers
Remove kickplate from kenmore dishwasher
Screech in door
2 Suggested Answers
  • 85 Answers
SOURCE: I have a kenmore dishwasher but no kickplate. How
Hello cantrell_m,
Sears appliance parts can supply you with the part you need. You will need to provide the model #. Here is their phone # (800) 252-1698.
I hope this is helpful for you. Positive feedback for me is appreciated. Thank you! NormanZ
Posted on Jul 14, 2009
What are the dimensions on a Kenmore 363.14192992 dishwasher?
Dishwashers that are installed into standard kitchen cabinets have a standard width and depth of 60 cm (Europe) or 24 inches (US), and most dishwashers must be installed into a hole a minimum of 86 cm (Europe) or 34 inches (US) tall. Portable dishwashers exist in 45 and 60 cm (Europe) 18 and 24 inch (US) widths, with casters and attached countertops. Dishwashers may come in standard or tall tub designs; standard tub dishwashers have a service kickplate beneath the dishwasher door that allows for simpler maintenance and installation, but tall tub dishwashers have approximately 20% more capacity and better sound dampening from having a continuous front door.
Feb 06, 2015 | Kenmore Dishwashers
Remove kick plate
Tip the unit back and put your hand under each side in turn underneath, the kickplate is held on via clips near each front foot (the retainer lug is part of the kickplate) this will release it. To reinstall offer the kickplate up under the door panel and give the bottom a push to relocate the clips.
Mar 19, 2013 | Bosch SMS68M02AU Dishwasher
How do you stabilize a kenmore dishwasher not to move
Greetings,
open the door and there should be two brackets that screw into the counter to hold the top. I would remove lower kickplate and you will find legs that you can move up or down,...I would set your d/w in place and scew the legs up to desired position...Then, screw brackets into top above d/w..this will hold d/w into place..if your happy with my answer. please let me know....thank you,
..........................Bruce Denton Master Appliance Technician
Dec 28, 2010 | Kenmore Dishwashers
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
How to disconnect
To disconnect ....remove the kickplate...after turning off the electric and water...remove the electric wire from the dishwasher by opening the e;electric box and undoing the wires...also remove the water pipe/hose from the inlet valve...then remove the drain hose from the drain and makes sure that it will not catch as you pull out the dishwasher...then remove the two screws that hold the dishwasher fast to the countertop and the pull the dishwasher straight out from under the countertop...
heatman101
Sep 15, 2010 | Kenmore Dishwashers
Brand new dishwasher but leaking water out the door. all plumbing is secure.
Confirm that the unit is level and the door seal is in full contact with the face of the washer.
If that is OK, remove the kickplate and use a flashlight to find the source while the unit is running.
Feb 16, 2010 | Dishwashers
Water does not drain in my kenmore ultra wash iii 16779
Hi!
Thanks for using FixYa. Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, or flip the appropriate breaker in the circuit breaker panel. Locate your dishwasher's water inlet valve. It should be located behind the lower kickplate panel in either the right or left corner. There will likely be two screws either on the top of the panel, or on its bottom. Remove these two screws, and then remove the kickplate. On some dishwasher models, the door has to be opened in order to gain access to, and remove the kickplate’s screws. Close the door before you remove the kickplate panel.
You will be able to identify the water inlet valve by the hoses that connect to it. There will be one hose feeding water from the house to the water valve, and another hose leading from the water valve that carries water away. Now is a good time to inspect your dishwasher's hoses, to make sure they aren't responsible for any water flow problems. Make sure the hoses are securely connected to the valve. Also check to make sure there are not kinks in the hoses. Kinks can impede the flow of water.
There will be two wires connected to the water inlet valve. If your dishwasher's water inlet valve has two solenoids, then there will be four wires. Label the wires so that you will be able to correctly reconnect them later. The wires are connected using slip-on connectors. Grasp the connectors and pull on them firmly in order to disconnect the wires from the valve's terminals. Do not pull on the wires themselves. You may want to use a pair of needle nosed pliers to help you.
Use your multi tester to test the valve for continuity. Set the device to the ohms setting x 1. Touch each of the meter's probes to a terminal. If you receive a reading of infinity, it means the valve's solenoid is faulty and the valve needs to be replaced. If your valve has two solenoids (four terminals), test the second pair of terminals in the same manner. If either pair of terminals receives a result of infinity, replace the water inlet valve.
You do not have to remove the water inlet valve from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
Interestingly enough, it is entirely possible for your water inlet valve to pass the continuity test and still need replacing. This is because sometimes the valve itself is faulty, but its solenoids are not. For instance, a leaky valve may pass the continuity test, but because it is leaking, it should be replaced anyway. The same applies to valves that are filled with debris. The debris may be what is causing the valve to not function properly. If you are unable to clean out a debris-filled water inlet valve, you will have to replace it.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | Kenmore Dishwashers
Hello cantrell_m,
Jul 14, 2009 | Kenmore 24 in. 16462 / 16464 / 16469...
How do I change the front panel of my Kenmore protable dishwasher
Remove the strip at the bottom of the panel above the kickplate it should just pull right off and then you can get the panel out the strip is about a 1/2 inch wide that you need to remove and it just snaps in place in a little track I have a Kenmore 17829000 and thats how you do it on that one hope that helps
Jun 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher door spring
remove the lower kickplate open the door hook the spring on the hooked part of the door and then in one of the holes in the frame youll see
Jan 31, 2009 | Dishwashers
Dishwashers Logo
95 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
