Question about Garden
How to replace rear axle on Toro Wheel Horse
Toro Wheel Horse 520LXI 73547 200000106 Replace rear axle
  • 8404 Answers
SOURCE: NEED MANUAL FOR TORO WHEEL HORSE GARDEN TRACTOR 416-8
As far as I understand, fixya.com does not stock or sell this mataerial. The purpose of this site is to get direction on a course of action to follow ...
Here is my suggestion ... if you have looked in the manuals section of fixya.com and not found what you are looking for, visit the manufacturers web site which is probably www.toro.com/wheelhorse or something very similar ... Google it to find it ... or you could search www.archive.org
Thanks for using fixya.com
If this helps you, positive comments are appreciated
a
Posted on Oct 26, 2009
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
suzukiracing
  • 200 Answers
SOURCE: I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
daneinwv
  • 124 Answers
SOURCE: I'm interested in a snow
My name is Dane and I am going to assist you in solving your problem.
I looked up the information on this snow cab and I found out that it is a universal unit that should fit on any MTD mower 1997 or newer. It should be fine. I would, however, buy this from somewhere like a local mower supply shop or hardware store so that you have the ability to return it just in case.
Well, I hope I've helped. If you found this useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Posted on Dec 06, 2010
Testimonial: "Well, I've looked all over the internet and nobody that sells these will say that they do or don't fit. I thought the same thing, that it should fit. "
  • 264 Answers
SOURCE: WHAT CONFIGURATION DOES BELT GO
You can go here and get a manual. Theres a $2 charge but it's worth it and will certainly help you.
Posted on Jan 15, 2011
LEAKING OIL right transaxle
Johnny, Transaxle needs a new seal. you can get or order your seal from any local small engine repair shop. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TORO Wheel Horse Hub Removal and Transaxle Seal Replacement
Replacing oil seal on rear axle of Lawn Tractor 917 288250 ShopYourWay
2007 Craftsman 917 287210 Lawn Tractor with leaking Transaxle
Rebuilding lawn tractor transaxle Part 1 of 2
lawntractor transaxle seal Google Search Ord
Aug 25, 2016 | Garden
Need to replace the rear wheel bearing in the left
Replace them both at the same time. You\'ll need a shop press to get the old bearings off and to push the new ones back on. There are 4 bolts on the bearing cover behind the flange that have the studs on it that holds on the wheel. Take them out then take off the cover on the rear end. There is a horse shoe clip that holds the axle shaft to the gears. Remove the clips and pull the axle out.
Oct 10, 2014 | Cars & Trucks
How do I fix a rear wheel that's locking up on my Toro zero turn mower?
Replace axle or check to make sure everything is still good and greased
Jul 24, 2014 | Toro TimeCutter SS4260 - 22HP 42 Zero Turn...
How do you replace the left front wheel on your toro model 20005?
Remove wheel retainer pressed onto axle, replace with new retainer. Replace wheel tap on new retainer.
Jun 01, 2012 | Toro Garden
I bought a Toro rear wheel drive lawnmower last May.I have never had any problems with it until now. the left rear wheel sticks. With the power off, I can roll it a little and it will stick and then I can...
The gear drive is probably just a little dirty. You can clean and lube the gears by pulling of the rear wheels and then remove the rear drive gears. Clean them and the axle and reinstall. Be careful to reinstall in the same direction as was removed. A smearing of axle grease in the axle and inside of the drive gears should take care of this.
Also remember that TORO mowers come with a 2 year warranty. Go to www.toro.com to find your nearest servicing dealer.
Nov 04, 2010 | Toro Lawn Mower With Toro Power Tools
I have a self-propelled Toro Personal Pace lawnmower, Model 20022. Both rear wheels engage and rotate when I lift the rear wheels off the ground, but when I put the mower back on the ground, the right...
Routine maintenance is required on the drive gears on these Toro mowers and Toro doesn't tell anybody. Put a block under the rear end to lift the wheel off the ground. Remove the wheel. You will see the drive gear. VERY IMPORTANT: take good notes, pictures, etc..when dissasembling. Remove the outer snap ring retainer from the axle shaft. Next should be a thin washer. Remove the washer. Pay very close attention to the gear, as it has to go back on in exactly the same direction. Remove the gear. There is a slot in the axle shaft. Rotate the axle to have this slot pointed up. In the slot is a small key (rectangular piece of metal), remove the key. Under this key is a spring. It, and the key, is stuck in the axle slot, therefore not allowing the gear to drive the wheel. Dig out the key and spring, clean them and the slot. Put a dab of axle grease in the slot and reassemble. In my shop, this is part of a mower tune-up, and is recommended every 50 running hours. That is usually every other year for the average home-owner.
DO NOT TIP your mower over to do this repair. Mowers are just like cars, they like all 4 wheels to stay on the ground. Tipping a mower over can/will cause fluids to go places they aren't supposed to go.
This is a relatively simple repair and can be done with basic mechanical knowledge and basic tools.
Do the other side too, it needs it.
Sep 11, 2010 | Garden
1994 buick roadmaster, oil leaking out of right rear axle, checked brake fluid is full, could it be differential oil leak @ end of axle??
If what you see leaking is very oily and does not evaporate, likely it is an axle seal. If there are no leaks in the brake system, that's the only thing back there that can leak. If the axle bearing is going away, it can damage the seal so make sure you look for small shiny metal flakes behind the seal when you replace it or you will be doing the job again very soon. Can't remember...that IS rear wheel drive right?
Dec 01, 2009 | 1994 Buick Roadmaster
Remove and replace rear wheel bearing on 1997 f150
REMOVE DIFF COVER ON 3rd MEMBER THERE WILL BE A SMALL 8mm BOLT REMOVE BOLT SLID PIN OUT PUSH AXLE IN AND REMOVE HORSE CLIP DO SAME FOR OTHER SIDE PUSH AXLE IN REMOVE CLIP. YOU'LL NEED A BEARING PULLER TO REMOVE BEARING INSTALL NEW BEARINGS WITH NEW SEAL, INSTALL BOTH AXLE WITH HORSE CLIPS INSTALL PIN AND 8mm BOLT, COVER AND REFILL.
Nov 04, 2009 | 1997 Ford F150 Regular Cab
I have a Toro Wheel horse, 13-horse Briggs & stratton and have zero spark what do I look for. I replaced the spark plug and have a full charged battery. I know little about engines so if you suggest i...
Usually when you have zero spark, it's one of 3 things. Either there's a shutoff that is trying to shut it off when it's not supposed to, the coil is bad, or the flywheel key is sheared.
Jul 11, 2009 | Toro Lawn Mower With Toro Power Tools
TORO Wheel Horse Lubrication
this is like a snapper drive it has a rubber plug that you pull out and fill with 0 grease lube meaning 0 is the weight of the grease that comes in a tube. you can get it at any little small engine repair or automotive shop.
Jun 11, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
253 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
