Question about Electrical Supplies
I have a coleman powerhouse 4000 generator that will not start. It was sitting for several years at my father-in-laws house. I changed the spark plug, emptied the old gas, refilled gas tank with new
Sat for several years changed gas and spark plug
  • 211 Answers
SOURCE: looking for owners manual for coleman powermate 4000
Hi
First you need to change the plug with a new one with the same heat range(too long time).Priming the engine few times(put some gas in the cilinder through the plug hole)and start the engine until it runs constantly.
bestregards savumihai71
Posted on Feb 12, 2009
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
  • 83 Answers
SOURCE: three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Posted on Apr 02, 2009
stunt driver
  • 5 Answers
SOURCE: Older Coleman 3500 Watt generator, sitting for
there can be many reasons. need more info:
Is it Inverter typr generator?
measure output voltage - anything?
take back cover off generator itself, measure continuity of stator and rotor, and visually inspect windings. You'll find AVR module there too, it may be the reason.
Posted on Jan 13, 2010
  • 905 Answers
SOURCE: I have a Coleman Powermate 4000 watt generator.
Hello Pete,
Is fuel actually leaking from the bottom of the bowl, or is leaking out the air filter and running down to the bowl?
If the former, then your bowl bolt's gasket has likely deteriorated. This would allow fuel to run down the bolt itself. Note that some carburetors will have a fuel shutoff solenoid (to the engine, not to the carburetor) that holds the bowl on, rather than a bolt. There will still be a gasket though. Turn fuel off before trying to service.
If fuel is running out from inside the carburetor (through air cleaner, etc), then you have a float / needle that is stuck. This is quite common after a small engine has been in storage and fuel was left in the carburetor. The residue causes the float to stick to the bottom. Turn the fuel off, undo the bolt that holds the bowl on, and carefully remove the carburetor bowl. Use a can of carburetor and choke cleaner to spray out the "gunk" in the bowl, spray off the float, and then reassemble. If it still leaks, then your needle seat will need to be replaced as well.
Posted on Sep 15, 2010
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Cant get my power ate 8750 to start. Ran fine last year. Have changed spark plug, aded fuel stabilizer, will starting ether help?
My son in law drained the carborator 3 times to get the old gas out. Also put in an additive to the gas. He figured our unit had sat too long and the gas was getting old. It is running fine now. Just need to figure out how to idle it down.
Oct 28, 2012 | Coleman Powermate 7,000 Watt 13 Hp...
My coleman powerhouse dual fuel lantern brightens and dims continuously. could this be the generator acting up?
Hi bradley m925...
Try using the cleaner for the generator, it is a twist type crank, make a few turns on it if you have it.
If not then your right, replace the generator as it is faulty.
Please take time to rate me
Coleman Generators website...http://www.summitcampinggear.com/lage.html
Sep 21, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
I have a dual fuel, two mantles, coleman lantern. I have changed the mantles several times and they keep getting holes almost every time i light the lantern.
Make sure that the vapourised fuel is coming through the mantle before lighting up. You should hear a hissing sound when the flame adjusting lever is turned to high. If not it is possible that the generator is clogged up and that vapourised fuel is not getting through to the mantle. So when you light up you are essentially just burning the mantle. If the generator is knackered it will need to be replaced. One way to check it to remove the generator, primed the tank and turn the valve on. If fuel spurts out when the generator is removed (DON'T LIGHT IT U)P THOUGH) but there is no hissing sound when the generator is intact then it is a sure sign that the generator is clogged up. In the UK a replacement generator should set you back £10-15. Hope this helps, Bandit
May 23, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
I'm looking for an owners manual for a Coleman Powermate 4000
You may not be able to find the owners manual, but if you search using model / type #s off the engine, you may be able to find the manual for the engine from the manufacturer.
May 07, 2010 | Coleman Electrical Supplies
Looking for owners manual for coleman powermate 4000
Hi
Feb 06, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
126 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
