Question about Ferris IS2000 61"" Zero Turn Lawn Mower 5900586"
Blade belt diagram for an is 2000 61 inch - Ferris IS2000 61"" Zero Turn Lawn Mower 5900586"
I don't have a diagram but we just had to replace our belt and Here's how we did it. Note that the shiny gold/silver pulleys make contact with the flat side of the belt while the black pulleys make contact with the u-shaped side of the belt. If you look at the pulleys you will see they have different shapes to correspond with the different shape on each side of the belt. The drive pulley at the back makes contact with the u-shaped side of the belt.
Release the tension spring and thread the belt. Belt slips under the middle back pulley with the tension spring released. Then use a spring pulling tool (there is such a thing) or another method to pull the tension spring back over the bolt. Ensure belt is threaded properly with no twisting and nothing caught in the pulleys before firing it up.
Hope that helps.
Posted on Jul 15, 2013
LT 1045 Belt Driven Blade Platform 46": Belt is too short to accomadate the sugested pully patern. I purchased 46" replacement belt that is recommanded.
Contact the manufacturer/distributor and obtain a belt installation diagram as well as confirmation that 46 inches is the required length.
Jul 10, 2017 | Garden
I have a vintage Murray Riding Mower, model number is missing has three blades each blade is 15.5 inches Need belt diagram to install both belts to deck
If you have info numbers off the engine, usually found stamped on the top front area, it should at least give you an approx. year.
Sometimes there is a belt diagram under the foot rest area.
Worst case : The belts always fit/sit with the flat part to the flat pulleys and the v part of the belt to the v pulleys.
Oct 24, 2015 | Murray Garden
Primary belt motion belt diagram for a murry 46 inch cut 2006 model
just did another murry today there is a sticker of the belt routing on the bottom of the foot rest
May 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
Replaced drive belt on 1985 38 inch cut MTD lawn tractor, belt id smoking
Your rubbing something that's not moving I suspect a belt idler or blade hub, as for diagrams the internet has them http://cf.mp-cdn.net/db/30/8c384c4f3c61628a0487bed5f925.jpg
May 05, 2012 | Garden
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
The newly purchased deck belt turning the blades is extremely loose
If idler is in tact and spring attached, it is likely that the belt isn't routed properly. If you try to route the rear-most portion of the belt around the idler, it will be loose. You must route the front-most portion of the belt around the center blade pully and then around the idler. Just Google "MTD 46 inch deck diagram" and you will go to a Parts Tree site with the proper diagram showing routing.
May 26, 2009 | Mtd Garden
I need to change the blade belt on my troy bilt 33 inch walk behind mower
look up on the internet the make and model of your mower and look under diagrams
May 22, 2009 | Garden
Z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
May 12, 2009 | Oregon Scientific Oregon Gator Mulcher...
Ineed the diagram for a 42 inch deck troy bilt
We I disengage the blade belt always comes off its to loose I have had the number checked they say its the right belt but its so sloppy
Apr 26, 2009 | Garden
Ferris IS2000 61"" Zero Turn Lawn Mower 5900586" Logo
742 people viewed this question
Top Ferris Garden Experts
ka4iup
ka4iup
kschlumberge
kschlumberge
Richard Schanie ...
Are you a Ferris Garden Expert? Answer questions, earn points and help others
