Question about Oreck XL Professional Air Purifier
I am trying to clean the dust out of the machine and i cant open it
Is this invrioionizer safe for people with heart or lung disease
Those devices use a process call IONIZATION to clean the air. What this does is make high voltage that jumps out into the air and attaches to particles in the air. Those particles are now attracted to anything with an opposite charge. In some machines there is a plate that has the opposite charge and a fan that pulls the air into the machine. When particles that are charged come into the machine, they are drawn to that plate and stick. The plate gets dirty pretty fast and has to be cleaned. The problem comes when the ionizer begins to spark. This creates ozone and ozone is harmful to people and animals, rubber and many other things. I looked up the name of the machine that you listed and the closest I can find is a really old reference to a radio shack device. the Environizer™ (630-0612/630-0613) This device was made just after regulation by the federal government that says 50 parts per billion is the limit so that device SHOULD be ok. However it has to be maintained and cared for. There is a great article here:http://www.allergyclean.com/problems-with-ozone-generators-and-ionizers-that-produce-ozone/
Just keep in mind the difference between ozone generators and air ionizers, they are not the same thing. If you need more info let me know.
Mar 11, 2016 | Air Air Purifiers
Lasko blower fantype DTB E20739 PM7331
to clean your fan from dust
Jul 02, 2013 | Air Purifiers
Fresh air is making a popping sound
Carefully examine the plate. If there are black burnt spots next to the wire, it needs to be replaced. Otherwise, cleaning it will stop the popping sound.
May 13, 2012 | Ecoquest Fresh Air Air Purifier
No matter how much I clean the machine after it is turned on for 10 min or more it starts to buzz and make a static noise, any other suggestions?
The buzzing noise is not from dust in the air purifier, it's from the dust and pollutants in the air, it's now picking up. It should stop once the air is cleaned.
Apr 17, 2011 | Ionic Pro TURBO Air Purifier
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
Cleaning the top of the oreck air purifier
what i normally do, is i take off the top of the and remove the filter, the metal dust catcher, and the back filter... i was the 2 filters and rub them down. then with the metal dust catcher i take a butter knife. wrap it in a clorox wipe (making sure that no metal is exposed to scratch) then i feed it through the metal dust catcher one at a time to clean it. It took me 5 wipes to clean the whole thing. when the wipe comes out black then i rotate it. As for the top of the machine. there are 2 screws that i removed to get to the fan. when they were out i used a can of air (like you would clean a computer with) and blew out the fan... it took care of all noise and it runs just like the day i got it.
Jan 12, 2009 | Oreck XL Professional Air Purifier
How to Clean The Unit
There is a screw on the bottom of the unit. When you remove it, the whole insides can be slid out. Then just blow the dust off with canned air. Wal la, you're done!
Jan 16, 2008 | Ecoquest Flair Air Purifier
Honeywell HFD 135 FAN BLADES DIRTY
I used a can of compressed air to clean my fan blades and this did the job. I bought a 6-pack of 3M Dust Remover at Sams Club to save money. Hope this helps.
George
Dec 18, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
Ionic pro won't turn on
Solution, perhaps...
All electrical contacts can get a film on them. Try cleaning the contacts (at the bottom of the blade unit; you should see the three with the blades out) with an alcohol swab (make sure the contacts are dry before reassembly in this case) or a pencil eraser (vacuum the debris out before attempting to start it again).
If those contacts don't make up properly, the unit will think it needs cleaning, even though it doesn't.
Mar 27, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Oreck XL Professional Air Purifier Logo
Top Oreck Air Purifiers Experts
brian kossman
Level 1 Expert
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
