Question about 2wire 2700HG-B Router (2700HGB)
Can't access my DVR remotely via Video Server E
Changed out my DSL modem to a 2wire and now can't log on remotely to view my DVR. I am using a AvTech DVR and 2wire with dyndns url service.
I've tried DMZ, allowing individual applications to pass thru the firewall with no success. I've pinged successfully, accessed the DVR via browser and Video Server E locally.
  • Anonymous Jan 27, 2009
    i can't connect to my dvr after i swap to 2 wire. also i cannot connect to my DVR remotely
  • one-eyed_joe Apr 16, 2009
    I have the same software and ADSL, I can access dvr web interface locally and the client works locally. Also I can access my router remotely and have port forwarding and dyndns set up. I have also tried putting the dvr in DMZ to no avail. The router logs show packets from my remote location stating that they match my firewall rules however I am not getting through to the dvr. I can even use my dynamicDNS url locally on the wireless LAN to connect via web or client. Any help would be greatly appreciated as tech support from manufacturers and ISP has been exhausted.
Try checking to see that you set up the DNS address correctly on the DVR itself. Either set it to the router (typically 192.168.x.1) or the same DNS address as the router.
Posted on Dec 05, 2009
Why i cant remote access my dvr in WAn but LAN is working fine?
Posted on Aug 28, 2009
Check whether you have done port forward on your router settings.. You can also see your router manual in order to get complete description regarding this.
Posted on Jul 26, 2012
Http://192.168.1.254/ has been put into my home page browser but nothing happens
IP ADDRESS 192.168.1.254 is the default gateway of an AT&T modem router (RESIDENTIAL GATEWAY) (2WIRE). for this ip address should be able to view the main screen of your 2wire modem and if not your computer is connected to a different network.
1) try connecting the computer to the 2wire RG using a ETHERNET cable (if your connected via wireless)
2) make sure that the DSL light is solid and not blinking.
3) if your computer already connected by a ETHERNET cable, try accessing the same ip address if your able to view the main screen of your 2wire modem it means that your computer will be able to connect to the internet.
4) try this also:
this for internet explorer:
click tools - connections - LAN settings
( if there's a tick mark on PROXY SERVER remove it )
if you do have tick mark on PROXY SERVER then your computer have a virus, because virus can put a tick on PROXY SERVER without you noticing it.
after removing the tick you will be able to connect to the internet again.
Apr 10, 2011 | Computers & Internet
Can't access modem from desktop
If your DSL works on PPPOE then you need to setup PPPOE on the 2wire router with the Complete Username and the PAssword for the PPPOW connection, if your DSL works on a Local IP address like 192.168.1.254 or 192.168.1.1 then first check the gateway address of the 2wire Router, if it's in the same IP address range like the DSL Modem like 192.168.1.x the you need to change the Local IP address of the router from 192.168.1.x to 192.168.2.x that should get you up and running with the DSL Modem.
Mar 25, 2010 | 2wire 2700HG-B Router (2700HGB)
I need to access a remote LAN through the internet. our church office is on verizon DSL with a westell 7500 modem. I have security camera's attached through an Ethernet cable. I need to be able to use...
You need to install a software that will manage your LAN's video recording. That software should work fine within your LAN and is usually provided with the Video Capture Cards where your cameras are connected. This software should have a web portal for you to access via internet utilizing your forwarded port. Thus, you must tell your video software to use your forwarded port for internet viewing. Without this web portal, you can't access your remote LAN videos via internet.
Feb 01, 2010 | Computers & Internet
2-wire modem won,t come up in connections,and don,t know how to configure modem dsl light solid green and can,t find lan settings,it,s a 2071-a
If you know your local network address side address then just log into the 2Wire with "http.XXX.XXX.XXX."
Example my 2Wire: "http.192.168.1.254." I'm not sure but I think the 192.XXX.XXX address is default.
The box has a little web server that will allow you to reconfigure to default but if your provider programmed it you may need info from them.
Sounds like the DSL side is working.
Oh, if you have the info from your provider to set it up, you might have to push the reset button on the box to reset it to factory default.
Then it gets a little complicated.
Nov 18, 2009 | 2wire Computers & Internet
Can't log on remotely
did you set up a port to connect through if not you need to set one on the port your DVR needs and forward it. It is called port forwarding.
Sep 29, 2009 | Home Security
Cant access lorex DVR from the internet
u need a public ip with an open port, and portforward the port with the ip of ur dvr
Mar 15, 2009 | Home Security
DSL connection not being shared by Linksys RV042 Dual Wan router
Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
Feb 24, 2009 | Linksys RV042 VPN Router
SECURITY CAMERA SYSTEMI
Have you setup a Virtual Server within the D-Link router? This should be on the ADVANCED tab in the D-Links Admin Configuration interface. Upon setup, the router should allow pass through of your request to the network connected device.
You will need the following in this configuration:
Name of device: SSC21WEB (or whatever the name of your device is)
IP Address: 192.168.0.101
Protocol Type: TCP
Public/Private Port: 10000 - 65535
Schedule: Always
Good Luck...
Oct 08, 2008 | Samsung SSC DVR Digital Video Recorder...
DSL (2wire modem) and LAN conflict
You can actually try accessing the interface of your gateway and put it on DMZ mode. That way it will open the ports on your gateway to ensure passage of all data from your gateway to all your computers even when the dsl is on. But make sure tat you have security software installed on all your computer workstations bec. putting your 2WIRE gateway on DMZ mode will expose your connection.
Aug 15, 2008 | 2wire 2700HG-B Router (2700HGB)
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
2wire 2700HG-B Router (2700HGB) Logo
2,901 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
