Removing agitator hoover 800EL
The agitator on my hoover 800EL washing machine seems to be fixed. When I try to lift it up there is no movement of the agitator itself, but it pulls the whole bowl upwards. There is a stocking and cord of some sort wrapped around it. I would hate to force it - not that I actually have the strength - or break it. I would also like to clean the inside part of the agitator where the softener goes. Any solutions?
  • 15,935 Answers
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
How do I remove the agitator from an old Hoover 2315L?
Agitator itself just slides on splined shaft. At that age it's undoubtedly "growed" on there and isn't going to be easy to pull in all likelihood. Brute force and awkwardness are about the only tools as it's rarely possible to get any leverage in any place that will do any good and the edge of the agitator itself away from the center is generally to weak to use as a pry point, anyway. Some have a removable cap at the top that can either be unscrewed or pried out depending on the make/model -- if so, you can sometimes from that point actually see the splined shaft and get some solvent down there to help. Unfortunately, ime, the "goop" has always signified a transmission shaft seal failure and nothing less than replacing that seal will solve the problem
Jan 16, 2017 | Hoover Vacuums
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Hoover 800EL Top loader will fill and empty but will not spin? Making a whirring noise like it is trying to?
Try replacing the large capacetor. This is called apon to give the motor the kick it needs to go into spin. For reference I include a picture to help you locate it.sparkyuiop.jpg
Apr 06, 2011 | Washing Machines
Help my hoover w/machine will not agitate or spin.
ok does that mean u know how to bypass lid switch so u can see the agitator and bowl while it is cycle? normally when the lid is lifted the machine stops.sorry to ask u this question but it will help in fixing your unit.please reply 4 more help.
Apr 15, 2010 | Washing Machines
Hoover 800 washing machine
take the cap of the top of the agitator you need a 10mm socket
on along extension bar undo the bolt in the bottom of the agitator and it will lift out replace by do-ing the reverse process
i have just done it better than paying $100.00 for a service call
for five minutes work
Aug 18, 2008 | Hoover HTC243 Top Load Washer
Object caught beneath the adigator
Remove the fabric softener by pulling and pushing to one side.
Once removed, there will be a half inch bolt that holds the agitator to the transmission shaft. Loosen the bolt and the agitator will lift off.
Older Hoovers have a set screw near the middle of the agitator.
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
Jun 21, 2008 | Hoover Washing Machines
Hoover 800el not spinning
hi all, I have a hoover 800el washing machine and it's making a clicking/ratchet noise. any idea what's causing it?
Kind regards
Louis
May 18, 2008 | Washing Machines
How do I replace a drum paddle in my Hoover washing machine HSWF167
there should be a plug on the top of the agitator. pry off this cap with a screwdriver. you will see the hex nut that fastens the agitator. remove the hex nut and lift the agitator from the transmission shaft. Installation is the reverse of removal.
Mar 17, 2008 | Washing Machines
Washing Machines Logo
201 people viewed this question
Top Washing Machines Experts
