Question about Philips GoGear Flash MP3 Player
File system error for gogaer 4gb,Model:sa3245/37
Every time i try going on my gogear it always says FILE SYSTEM ERROR. P.S.it realy sux
  • Anonymous Mar 19, 2014
    just dont on! :C
Im having the same problem! if you find out how to fix it please let me know!
Posted on Jan 03, 2009
  • 210 Answers
For sure, the file system is corrupted and is the cause of your woes. The fix lies with the Philips Songbird software. If you do not have Songbird, download it for Windows or Mac here:http://www.usa.philips.com/c/mp3-media-player/22126/cat/en/#/difference/philipssongbird.
Once you have Songbird installed, launch it and select "Repair my Philips device" in the Tools menu. Select your device and follow the instructions specific to your device. For example, instructions for the GoGear Vibe are to disconnect the device, power it down completely, and hold the volume-up key during and after USB connection until the message window disappears.
If the repair utility endlessly indicates it is checking for updates, you are likely using an out-of-date version of Songbird - probably the one that came with your GoGear. If this describes your situation, launch Songbird and select "Check for updates" in the Help menu. This will at least get you upgraded to version 1.9 (currently), even though the latest version is 1.11 (currently).
Instructions that came with some older versions for connecting GoGear in repair mode were incomplete. They left out a crucial step of turning off the GoGear and waiting for it to power down completely before reconnecting in repair mode. Newer versions of Songbird include the ability to reformat the device, reset the device, and to get progress updates during synchronization.
If you've found this information helpful, please indicate as such.
Posted on Apr 04, 2013
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
My gogear if frozen. Will not power off.
Hello :
PLEASE DON'T FORGET TO RATE !
Apr 18, 2010 | Philips GoGear Flash MP3 Player
Dont no how to put vidoes on my mp3
This mp3 / video device willl require a converter program for putting videos in the matching format before transferring to the player.
For the correct downloads for your player select the GoGear Flash 4GB on this search page listing all 4GB Flash players:
http://www.search.philips.com/search/search?h=all&o=support&l=global&s=all&q=GoGear+Flash+4GB+video
Select your exact player model from the list. 2 Players are on this list.
When having another model, enter the typical name / size / functions in the search bar.
Once selected the exact model all support for the GoGear will be available:
updates; frequently asked questions; quick start guide; user manual and software & drivers downloads.
Media converter software can be downloaded as a zip file.
Right click and select "Save Target as..." the zip file to a location on the computer.
Next unzip the file.
Finally run the Arcsoft mediaconverter for conversion of your videos into
the fitting format for your player.
If this was helpful I'd appreciate your vote.
Just post a comment when needing more help.
Jan 02, 2010 | Philips GoGear Flash MP3 Player
File error
User manual for SA6044, SA6045 and SA6046 availble in pdf format:
http://www.p4c.philips.com/files/s/sa6045_02/sa6045_02_dfu_eng.pdf
All universal support for SA60 with next link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=ENG&searchtxt=sa60
Select your model from the list.
Use the link item 2:
"What should I do when my player is not recognized by my PC ?"
and follow the instructions.
It is possible that you'll have to reinstall firmware or software. It can
be downloaded from the support link for your exact model.
When more help is needed just post a comment.
Sep 18, 2009 | Philips GOGEAR SA6045 MP3 Player
File system error comes on every time i power on my philips mp3
try to get the latest software updates for your product from the philips website or format the pen drive to another file system
Feb 05, 2009 | Philips GOGEAR SA6045 MP3 Player
How to format philips gogear mp3 player?
I wouldn't format it. If you are having problems, run a Repair in Philips Device Manager. If you are getting format errors, then the songs you are trying to load are not compatible with the player - if you download songs that are in true mp3 format, then you will not get any format errors.
-Tha Mp3 Doctor
Jan 25, 2009 | Philips GoGear SA3125/37 MP3 Player
Where can i get the video converter to convert videos into .smv files. for gogear 4gb
www.usasupport.philips.com
Enter your model #, click on your model #, and go to the Software & Drivers section
-Tha Mp3 Doctor
Dec 18, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips 4GB GoGear Flash Audio Video Player - Video Error
just download youtube converter it is freeware.add the file ,choose the format i.e avi ,get the output file .now load it on philips media converter it will read and work.
Oct 09, 2008 | Philips GoGear Flash MP3 Player
Phillips GoGear 4Gb - Can't sync songs onto player...
This is only a makeshift solution.
I use a philips gogear sa52xx and found out, that deleting the drivers, then reconnecting the Player and pressing F5 in the explorer allows me to normally access the philips gogear sa52xx for about 30 seconds. After that, out of nowhere the drivers will sever and the Code 10 error appears. So, another disconnect - deinstall of the driver - reconnect - F5 in the explorer until the Player appears and then sync. The proplem is, that this works best (maybe only) with mp3 files...
So convert your music files into mp3 first, than do above steps for drag 'n' drop.
Usually, you need to do the whole procedure 2 times for a CD, sometimes 3.
Oct 31, 2007 | Philips GoGear SA178 MP3 Player
Phillips GoGear 4Gb - Can't sync songs onto player anymore.
Software can be found by going to:
Enter your model number
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "software and drivers"
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Philips GoGear Flash MP3 Player Logo
498 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
