Question about Sewing Machines
Feed dog died
My machine has had very little use in the 1 year I have owned it, purchased brand new. Today, as I was sewing my daughter's costume, the feed dog just stopped working! It was working fine, then it stopped. It is also "growling" when I begin to sew. I took apart and cleaned under the bobbin case and it is still not working. What else can I try?
  • Sewing Machines Master
  • 1,564 Answers
Sounds like a gears problem. Take it in for service
Posted on Nov 12, 2012
  • 255 Answers
SOURCE: Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Posted on Jan 10, 2008
bargainbox
  • 1388 Answers
SOURCE: Kenmore Sewing Machine 16221 will not feed
Check for lint buildup between the feeddog teeth, will look like felt pads.....remove it !.........this little housekeeping should be done regularly......also ensure the correct stitch length is selected, not set at zero (OK, unlikely, but can happen !!)
Posted on Apr 24, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
SOURCE: Bobbin Case Popping Out
Hello i have singer 7422 for several month it was working fine until i notice the bobbin thread is not pulling up by needle.when i called the siger customer service they told me my sewing machine is out of time ,so any one had same problem with there sewing machine or can tell me how i can fix my wife sewing machine.
Posted on Dec 31, 2008
Feed dog problem
take the machine back & get another one or ask them to have the machine fixed.
Apr 01, 2014 | Janome Magnolia 7330 Sewing Machine
The feed dogs of my shark 801B don't go up how can I fix that
the machine needs to be checked to see if the feed dogs broke
or were damaged
Jan 23, 2013 | Sewing Machines
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
Possible broken feed dog on a White sewing machine
you can either take it to a sewing machine shop & have them check it or
or try sewingpartsonline.com or premiersewing.com
if you try one of the websites, look for the name of the machine first & then click on it & then look for the model number & see if they have the part
normally it's a feed dog lever or knob
Mar 15, 2012 | White Sewing Sewing Machines
Feed dogs not moving properly
it's very possible that the feed dogs are out of time & the machine would have to be serviced at a sewing machine repair shop
Mar 05, 2012 | Kenmore Sewing Machines
I have a necchi model 575FA, and the needle will not advance any idea why?
if the sewing machine is not sewing & staying in one spot the that means the feed dogs are not working properly.
I also have a necchi sewing machine, check the needle plate area that's where the feed dogs are, if the feed dogs are up where you can see them & even feel them with you fingers when you rub your fingers over the needle plate area, if you can't see them good or feel them, then they are not up,,my instruction book shows that you have to remove the extension table, their should be a small door in front of the needle plate area to open that's where the feed dogs are if they are not in the up position, where you can sew, if they are in the down position move the lever to the opposite direction & see if that help the machine to sew, if it make makes no difference which position there in , then it's possible something is wrong with the feed dogs & the machine needs to be serviced
Sep 18, 2011 | Necchi 3101 Mechanical Sewing Machine
I own a Necchi model 535f......I have had it cleaned and oiled in the last 4 years....I can't get my fabric to feed through my machine
The feed dog & the presser foot have to work together to feed the fabric thru the machine
The feed dog should be seen when you look at the needle plate, if not the feed dog setting should be checked--the feed dog lever may be to the right of the bobbin area
Open the light bulb door also called the Lamp Cover door or Face Plate,, there should be a knob at the top round or star shaped,, that adjusts the needle bar that puts pressure on the presser foot,, it may have numbers or letters, mine is a star shape & has numbers on it & is set between the 2-3
Adjust it a little at a time & then sew to see which setting is best for your machine
Oct 21, 2010 | Necchi Sewing Machines
I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Aug 03, 2010 | Singer Sewing Machines
The dog feed stuck in the downward position.
Have you turned the machine off and then back on?
The switch may be broken and you will need to find a sewing machine repair shop that repairs all brands of sewing equipment.
If you decide to purchase another machine try a different brand. This one seems to have on a lot of issues.
Feb 19, 2010 | Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
