posted by rath on May 14, 2007
Bosch WFMC3200 front gasket came off. Was able to put the gasket back on but can not figure out how to reinstall the spring-loaded mounting ring. Is there a trick or technique?
Comment by rath, posted on May 15, 2007
Thanks for the advice. I will be trying the two person idea tomorrow night.
Solution #1
posted on May 14, 2007
no trick or technique - just a pain to do. don't be afraid to stretch it and if done as a two man job its far easier. one way i thought of was to make a former of approx the right diameter and slip the ring from the former on to the door boot
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bosch WFMC 3200 Front Load Washer
Email this problem
Email this problem
Can you Help with these Washing Machines problems?
Machine too heavy to move
I can't slide my new machine... Answer This...
Door Open, Door Latch Locked
The door to my WFMC3200 is... Answer This...
bOSCH WASHING MACHINE RETAINING...
Hi I saw your answer and... Answer This...
Rubber gasket Bello!
What is the trick to installing... Answer This...
BOSCH WASHER REPLACEMENT PART
bosch wfmc3200uc washing... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
