Question about Jeep Lantern
I lost the remote to the jeep lantern how do i turn it on manually?
Why does my 2004 jeep liberty sport door remote lock and unlock the doors but lights don't flash no more
its programmable
the operators guide (lost that ) tell you how to turn that on or off.
its a feature.
lost that
its still fire this year, and will not be in 2016, my guess.
so now's the TIME.
http://www.jeep.com/en/owners/manuals/
Dec 03, 2015 | Jeep Cars & Trucks
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Tip
Parts Callout
INSTRUCTION MANUAL PARTS LOCATOR
1. ANTENNA
2. BATTERY COMPARTMENT
3. CARRYING HANDLE
4. COMPASS
5. SPEAKER
6. LCD CLOCK DISPLAY
7. BACK LIGHT (CLOCK)
8. MODE
9. SET
10. FLASHLIGHT
11. LANTERN / FLASHLIGHT / OFF
12. BLINKER I SIREN / OFF
13. WEATHER BAND/AM/FM SELECTOR
14. TUNING
15. VOLUME ON/OFF
16. LANTERN
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours http://www.coleman.com/Parts/100/parts-lanterns/5317-702/remote-control-pack-away-family-size-lantern# then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
My mom purchased this Jeep lantern and does not have the manual that came with it. I don't know how to get the light to stay on. She uses this to get across the street to get her mail. She is an 82 ye
Hi, I'm having a similar issue with my jeep lantern as well. It's actually a really nice lantern, however, when I plug it in with the power cord, it seems like it is A LOT brighter than when it's just running on batteries alone. When using the turn button, it does get brighter and dimmer, just not to the extent I would like it to be as I use the lantern at night as well to do things such as checking the mail and going to my vehicle. I feel much safer with the light at night, but obviously can't keep it plugged in when walking around my property. It just is not as bright running on just the batteries. I'm not sure if there is a mechanical error with the product, but I've never noticed the difference between the brightness until recently. I changed the batteries and it just didn't make a difference. Just wanting to get some advice to see what I could do to try and make the light brighter. Maybe it has to do with the new batteries I bought, however, they are GREAT batteries I purchased and I don't think that is the issue. Some suggestions would be helpful. :)
Nov 16, 2013 | Jeep Lantern
Need manual for jxltv
I couldn't locate the manual for it but here is the website I believe. http://www.allthingsjeep.com I would contact them and see if they have a manual for it. If not ask them where you can get it.
Oct 25, 2012 | Jeep TV/AM/FM Radio/Flashlight/Fluorescent...
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Nov 22, 2011 | Camping, Backpacking & Hiking
Manual for Jeep KNG36-JXLWBC AM/FM Weatherband Flashlight Lantern
I just posted a copy of the manual in pdf format on this web site however I have no idea how you would access it.
Sep 24, 2008 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Jeep Lantern Logo
44 people viewed this question
Top Jeep Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Jeep Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
