Question about Lennox 7 Series MS7-CO-12L MS7-CI-12L Cooling Only Wall Mounted Mini Split
Lennox CB30M-46-4P will not turn on
The product is a Lennox Elite Series CB30M-46-4P it will not turn on there is power to the unit. It is 5 yrs 10 months old and I noticed when I opened the unit up that there is rusting on the coils this is an inside unit and the outside unit does work.
Is there some way to get the owner manual for the Lennox pro series LN7
lennox support page:
Easy access to Lennox product documents
LN7 didnt pull any results so you might want to double check the model #
Jun 08, 2015 | Pool & Spa
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
Water is leaking into my garage when a/c unit is running. Lennox elite series cb29m-41-1p
Check your indoor unit. your problem is there. you will be able to see where the leak is coming from then I would be able to help you more
May 19, 2010 | Heating & Cooling
The fan is running and blowing cool air out of the unit but there is no air coming through the vents, what are the possible problems? (Lennox Elite series)
The unit could possibly have a frozen indoor coil. Turn ac to off...and fan switch to on...wait 45 minutes and see if air flow improves. Check for dirty filter which can lead to freeze up. Low on freon is also a possibility.
May 18, 2010 | Heating & Cooling
Lennox merit series furnace is not kicking on until house is 8 to 10 degrees colder then set thermostat
I have the same issue with a G21Q4-5-100-1 model lennox. House drops 8 - 10 degrees. I have 3 thermostats and all react the same way. I was told by service tech that the Ignition Coontrol Module is bad and acting intermittanely. ???
Jan 31, 2010 | Dayton Gas Furnace Heater
Lennox G40UH(x) series - Air not coming on
electrical connections @ the furnace may the thermostat .Tom
Jun 18, 2009 | Heating & Cooling
Lennox Elite Model # CB30M-65-4P I had my A/C fixed while back because the freon lines keep hitting each other from the vibration which causes a leak in the line every 6 months to a year and since then...
The copper the big line should have a insulating foam wrapped around it called rubetex which eliminates any rubbing. They should never be that close also. Now is this unit a heat pump?
Nov 24, 2008 | Heating & Cooling
Lennox 7 Series MS7-CO-12L MS7-CI-12L Cooling Only Wall Mounted Mini Split Logo
135 people viewed this question
Top Lennox Heating & Cooling Experts
Lawrence Oravetz
jeff5may32
tractorman44
tractorman44
Are you a Lennox Heating and Cooling Expert? Answer questions, earn points and help others
