Question about Sony DSC-T70 Digital Camera
No flash When I press the icon for the flash mode it is in the off position....How do I turn the flash mode back on?
  • 2 more comments
  • Anonymous Jan 04, 2009
    Same here, the various option for flash is gone! pls email waikiki6969@gmail.com if you can resolve this problem. Thanks.
  • Anonymous Jan 08, 2009
    Same problem here, there is not option to trun the flash back on, may be need to update the firmware?? need to contact Sony for help
  • jobrien618 Jan 21, 2009
    same problem here -- such a basic function shouldn't be so hard!
  • Anonymous Jan 28, 2009
    bint3gra solved this problem for me!!! Thank you!!! =)
Hey folks, i had the same issue, i was sooo annoyed. I looked in the dinky manual and found nothing. Turn your camera on with the lens cover closed. Hit Home, select the briefcase bottom right hand corner. select MAIN settings and hit OK. Select initialize, this will restore the camera to factory default values. Bringing back the flash. Don't ask me why it disappears after awhile. I thought i was going mental and m friends all thought i was an idiot. hope this helps.
Posted on Jan 24, 2009
  • 21 Answers
There should be a button/function that looks like a lightning bolt, that should turn on and off your flash
Posted on Jan 03, 2009
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center.
The flash mode button is the top button on the selector, it has a lightning flash icon.
Press the flash mode button on the multi selector.
Highlight the desired mode and press the center of the multi selector.
The flash modes are:
AUTO; Flash fires automatically when lighting is poor.
AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits.
OFF; Flash will not fire even when lighting is poor.
FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects.
SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light
The selected flash mode icon appears at the top of the monitor.
Oct 22, 2014 | Nikon COOLPIX L3 Digital Camera
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
I can't turn on back the flash on my Sony DSC-W350. what should i do?
Hi you might has flash unit defective if you set the flash mode properly. you can buy the part very inexpensive in ebay rather than sony manufacture.
Jun 02, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
How do I turn the flash on on my Nikon D70?
if u select mannual mode u have to press flash button,whitch is on left side below flash unit,if u select auto mode, flash itself elect when u half press the click button.
Mar 08, 2010 | Nikon D70s Digital Camera
How do I turn off the flash for the canon powershot a630?
First of all, the flash can not be turned off in "Auto" mode. You can turn it off in any mode other than Auto. Would recommend Program "P" mode, which is very similar to Auto, but allows you to modify certain minor items such as flash and white balance.
Rotate your mode dial to "P", then press the button on the back with the "lightning bolt" icon. Press until the lightning bolt with a slash shows up on your LCD screen. The flash is now turned off in Program mode. Try taking a picture.
Remember, if in low light conditions you'll need to keep the camera extra steady without flash to get a clear picture. Recommend placing the camera on a table or chair (or even better, use a tripod), then using its autotimer to snap the picture.
Nov 01, 2009 | Canon PowerShot A630 Digital Camera
Flash
Your camera is set at twilnight mode which has the flash suppressed and you won't be able to turn it on because of the fixed setting of twilnight mode to get the proper result of the picture. Due to the mode setting requirement, a shakey hand icon and no flash icon will show. If you press the flash mode button, it beeps. The twilnight setting has a low shutter speed, i.e. the shutter opens longer to allow more lights in, therefore it shows recording to let you know that the shutter is still open, and any moment of the camera will result in a blurred picture.
Now, check your camera mode dial and turn it back to the 'green' camera and see if you can get the flash to fire.
Jul 08, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
How do I turn my flash off on my samsung digimax 4010
You don't say which model Digimax you have. Hopefully this will cover most models.
First, make sure the menu is not being displayed on the LCD monitor, otherwise you'll just move around in the menu screen. You must also be in photo record mode, ready to take a picture (not in playback or movie mode).
There is a button (usually on the left side of the direction pad) that looks like a lightning bolt. I can't remember the exact number of times you must press it, but the display should indicate that the flash is turned off as one of the options as you cycle through them.
Depending on your model, the modes are likely to be Auto Flash (bolt with an "A" icon), Auto with Red-eye reduction ("eye" icon), fill flash - always on ("bolt" icon), Slow sync (bolt with an "S" icon), and flash off (bold with a line through it icon).
Also depending on your model, you may not be able to turn the flash off depending on which recording mode you're in. For instance, you can't turn the flash off if you're in the "Backlight" recording mode.
Dec 13, 2007 | Cameras
Portraits underexposed
Whenever you are taking pictures of people within six feet of them, it is a good idea to turn on the flash - whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the right arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Outdoor portraits underexposed
Whenever you are taking pictures of people within six feet of you, it is a good idea to turn on the flash whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the up arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Outdoor portraits
Whenever you are taking pictures of people within six feet of them, it is a good idea to turn on the flash whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the up arrow key, which has a lightening bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Sony DSC-T70 Digital Camera Logo
143 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
