Question about Craftsman 5600 watt Generator
Generator keeps stopping - Craftsman 5600 watt Generator
Ck the oil if its low it will not stay ruunning
Posted on Oct 27, 2012
My diesel kipor 5kva generator wont shut by key ,
Caution
the manufacture is recommending a cool down period of about 3 minutes to prevent overheating of the combustion chamber. the following is from the manufacture on shut down procedure.
3.2.8Check Stopping of Generating Set
(1)Disconnect the load from the generating set.
(2)Turn off the air switch of the generating set.
(3)Set the speed lever at RUN position, run the generating set without load for about 3 minutes. Do not stop the engine suddenly, otherwise the temperature will increase abnormally, the nozzle will blocked and the generating set will be damaged.
Press down the stop lever. Concerning the electric starter, turn the key to OFF. Turn the fuel **** lever to S position.
Pull out the recoil starter handle until you feel resistance (at this position, both intake/exhaust valve are closed.) and leave the handle in this position. This prevents the engine from rust.
If the engine keep on running even after the speed lever is placed at the STOP position, either turn the fuel **** to the CLOSE position or loosen the nut of high pressure fuel pipe on the pump side to stop the engine.
Do not stop the engine with the decompression lever.
Do not stop the generating set with load. Stop it after the load removed.
the following link provides the complete maintenance manual for the diesel generator
http://www.rcremers.nl/webshop/handleidingen?download=20:handleiding-aggregaat
Jan 12, 2016 | Kipor Electrical Supplies
Craftman generator keeps stopping
Under load? or idle?
Check oil level pressure switch and level
Oct 27, 2012 | Coleman Powermate Premium Plus 6250W...
Keeps stopping
which type of generator had an Olympian GP18 which would start and stop immediately, we were suspecting that the emergency switch had been pressed and left on but it so happened that the starter relay was the one loose.
Regards
George
Sep 01, 2012 | Cars & Trucks
Flywheel on 5hp generator keeps freezing up
sounds like bearings on your krank are going out
Jul 01, 2012 | Craftsman Briggs & Stratton Portable...
WHEN I START THE GENERATOR I HAVE TO HOLD THE START SWITCH ON TO KEEP THE GENERATOR RUNING.
The switch should be three positional.
The upper position is only for starting. Continuous running is in the middle (self holding) position. Lower position is to stop the generator.
If left in middle position it is not running you may have the switch bad, or the generator is stopped by low oil level.
Jun 03, 2010 | Watts Onan Portable Generator - 4000 ,...
My sdmo generator keeps shutting down temperature
http://www.aa1car.com/library/overheat.htm
Troubleshooting advice above link.
Sometimes it is the head gasket, check, it can be, incorrect fuel mixture, far too lean, exhaust should be a light grey color. Check enough oil in sump. ensure free flow of air all around machine.
Mar 28, 2010 | NEC Mitsubishi MGE 1800 Generator-Voltage...
My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Jun 20, 2009 | Electrical Supplies
Stops and starts
Most home standby generators are setup to run once a week so as to keep the engine lubed up and the generator windings dry. So if yours is comming on once a week at about the same time and running for something like 15 minutes, that's what is going on.
On the other hand, if your generator is starting and the switch is transferring somewhat randomly, you could have a problem with the neutral connection in your system, the power could really be going out and coming back on, and/or the control board in your generator could be broken.
Regards,
Carl
Mar 12, 2009 | Briggs & Stratton 15,000 Watt Home Standby...
Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
Sep 26, 2008 | Coleman Powermate Powermate 5000W...
Craftsman 5600 watt Generator Logo
191 people viewed this question
Top Craftsman Electrical Supplies Experts
BJ Russell
wadingriver
wadingriver
Chuck Graybill
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
